[Pipo-Project] M7Pro kernel
    OK - I've sorted the CT363 for once and all! As stated above - only flash AFTER successfully flashing a stock firmware in you have a CT363 touchscreen for now.
    v1.34.10
    Notes:
    Amended CT36x driver to be configurable and to avoid flashing new firmware.
    Donate to Finless
      1.34.09 - no changes to BT...
      1.34.10 - no touch screen
        v1.34.11
        Notes:
        Released GPIO reservations on CT363 TS
        comment out avs_init
        Donate to Finless
          Originally posted by d33 View Post
          v1.34.11
          Notes:
          wifi OK
          usb audio OK
          bt starts OK
          gps starts OK (did not go outside to test reception)
          touchscreen OK
          brightness range and progressivity OK
          sofarsogood
          here is syslog capture with an USB DAC attached while booting:
            Code:
            <6>[    3.906733] [BT_RFKILL]: Enter rfkill_rk_init
            <6>[    3.906791] [BT_RFKILL]: Enter rfkill_rk_probe
            <6>[    3.906832] [BT_RFKILL]: init gpio
            <6>[    3.906847] [BT_RFKILL]: Succesfully gained ap6476_poweron gpio.
            <6>[    3.906867] [BT_RFKILL]: Succesfully gained ap6476_wake gpio.
            <6>[    3.906883] [BT_RFKILL]: Succesfully gained ap6476_wake_host gpio.
            <6>[    3.906900] [BT_RFKILL]: Request irq for bt wakeup host
            <6>[    3.906925] [BT_RFKILL]: ** disable irq
            <6>[    3.906941] [BT_RFKILL]: Succesfully gained ap6476_rts gpio.
            <6>[    3.906957] [BT_RFKILL]: setup rfkill
            <6>[    3.907027] [BT_RFKILL]: Enter rfkill_rk_set_power
            <6>[    3.907041] [BT_RFKILL]: Set blocked:1
            <6>[    3.907051] [BT_RFKILL]: blocked is set to true
            <6>[    3.932477] [BT_RFKILL]: bt shut off power
            <6>[    3.932495] [BT_RFKILL]: reset GPIO is invalid
            <6>[    3.932515] [BT_RFKILL]: ap6476 device registered.
            <6>[  157.413977] [BT_RFKILL]: Enter rfkill_rk_set_power
            <6>[  157.414007] [BT_RFKILL]: Set blocked:0
            <6>[  157.414024] [BT_RFKILL]: Blocked is set to false, Wakeup!
            <6>[  157.414053] [BT_RFKILL]: Enter rfkill_rk_sleep_bt
            <6>[  157.414094] [BT_RFKILL]: *** bt sleep: 0 ***
            <6>[  157.442610] [BT_RFKILL]: Reset GPIO is invalid
            <6>[  157.442651] [BT_RFKILL]: bt turn on power
            All looks healthy
            Donate to Finless
              touchscreen ok
              but I'm still unlucky with BT
              This time, before I took the DMESG, I tried to turn on BT, transfer a file (unsuccessfully) and turn it off
              and there are absolutely no problems with BT on stock kernel
                Originally posted by raxy View Post
                wifi OK
                usb audio OK
                bt starts OK
                touchscreen OK
                sofarsogood
                Yepp, I think this is done now.
                Donate to Finless
                  Here is dmesg with the stock kernel, after similar actions:
                  cold boot, turn on BT, transfer a file (this time with success) and turn it off
                    i face something strange:
                    any request to Internet is slow as hell!
                    rebooted many times, reinstalled opera, cleared cache and dalvik cache without success,
                    will revert to another kernel to see if it is kernel related...
                    edit: flashed kernel 1.32.7 and internet speed became OK,
                    flashed kernel 1.32.17b and internet speed still OK
                    reinstall 1.34.11 then slooooowwww wifi
                    flashed kernel 1.32.17b and internet speed OK again
                      Hello, I am testing 1.34.11, but encounter something funny. On my tablet all Icons are exchanged
                      right to left. Volume up becomes back Home becomes volume down etc. With difficulty I got to settings
                      and the Kernel identifies as 3.0.36+ by darrell on May 20th. Hard to test further. Anyone have any idea.
                      I start to think that all M7's are different !
                      Kind regards to the developers, John
                        Do you mean the function of the icon changes? That probably means the touchscreen is reversed left to right (x-axis). I can build you a 'special one'
                        Donate to Finless
                          Yes, exactly so. I just checked version 1.34.10 and it is the same, earlier than that I think not.
                          Also not a problem with the Riley rom's. Would appreciate your help.
                          Kind regards, John
                            v12
                            Changelog:
                            Upped the VCC_Jetta voltage to 3V from 2.8. It has been reported to improve wifi chip stability
                            Reversed x-axis for CT363 Touchscreen
                            For Raxy & SteveJC - I've pushed the code so that you can get involved too.
                            [edit]
                            Just noticed that the original stock DMESG had this at 1.8v! I've made v13 with this
                            v13
                            Changelog from 11
                            LDO6 - 1.8V
                            Reversed x-axis
                            Donate to Finless
                              by the way, what is LDO8?
                              3.0V in the stock dmesg
                              2.8V with 1.34.11
                                2.8V with 1.34.11
                                Code tags are "vcc 28 cif" so 2.8v sounds correct??
                                Donate to Finless
