This is the same DMESG as .14 not kernel build .15
[Pipo-Project] M7Pro kernel
Originally posted by raxy View Post
This is the same DMESG as .14 not kernel build .15Measy U4B (=Tronsmart T428) used by my kids!
Donate to Finless
1.32.15 :
Touch screen OK
Wi-Fi OK
Screen rotation OK
Brigthness control OK
HDMI OK
BT - can't be turned on
GPS isn't workingAttached Files
Donate to Finless
Originally posted by TriA View PostOn my tablet, GPS was working with 1.32.03 kernel, but there was no hdmi
That's because the Pipo supplied source identifies the HDMI power pin and the GPS power pin both as the same (PIN1_PB5)Measy U4B (=Tronsmart T428) used by my kids!
Donate to Finless
Try these (a) has ct36x driver (b) doesn'tMeasy U4B (=Tronsmart T428) used by my kids!
Donate to Finless
Focus on HDMI & GPS. Please confirm their function in .16Measy U4B (=Tronsmart T428) used by my kids!
Donate to Finless
Hi d33, 16a the touchscreen doesn't work so I cannot test the GPS but the HDMI worked first time after flashing and then did not work again after resetting and powering the tablet back up. 16b GPS works but the HDMI worked first time after flashing and then did not work again after powering off and powering the tablet back up.
Oops. Ooooops!
I didn't test with powering the tablet off!
.16b kernel:
Bluetooth IS working after power cycle! Reboot was not enough.
HDMI ok, it works even while the tablet is booting up (at the time of rotating the RileyROM logo) and so further.
But GPS isn't working
All other features seems to be OK
By the way, backlight is flickering (like a candle) while battery is very low and brightness set to low.
I think, backlight hardware is unstable with low LED current and low input voltage, so minimum brightness wasn't set too low in stock kernels, because ot thatLast edited by TriA; 13 April 2015, 20:49.
Oh wait...
GPS seems to work too.
But. With screen turned off only.
If I put the tablet to sleep with GPS software running in background, it can see many (about 10-15) satellites and properly fix the position.
As soon as I wakeup the tablet, the number of satellites in view decreases one by one, to zero (sometimes 1-2), within 5-10 seconds.
So strange. I had no big problems with GPS on this particular tablet with JellyBean firmwares, although signal levels were not the best.
There are currently 2295 users online. 1 members and 2294 guests.
