upon cold boot, BT is off but turns on automatically when you enter the setings screen; and then it seems at least able to detect surrounding phones,
but if you turn it off, it cannot then be turned back on anymore, unless you do a complete power cycle (simple reboot will not do the job)
And usb audio does not work, the last kernel in which it had worked was 1.32.7.
