Finless 2.0a ROM for the Minix X8/X8-H
Originally posted by pablo11 View PostIf you do use a usb you should try the side slot. Have you unzipped the package?
Originally posted by glockman4519 View PostWhere are you putting the files at and what slot are you using on the device to put the rom on? I recommend an SD card and not a USB stick. There is a slot for an SD card on the device for this. I have never had an issue when doing it this way. Just some thoughts.
no v3 of finless? didnt want to flash the original one, but i guess i have no choice, in past was very fastAndroid devices: Minix X7 (gone) , Minix X8-H , MK808b Plus
Video Out: Benq W1000+ 1080p Projector
Audio Out: HDMI -> Yamaha RX-V467B + 5.1 Yamaha Speakers
Remote: Rikomagic MK702 II, Minix NEO M1
Storage: NAS Zyxel NSA325v2
I think that Bob was on vacation. I can't wait for him to build an update. Or I should say I am excited that there will be an update. I'm so tired of getting the "OTA update available For download". Bob, is there any way of taking the update notification out of the new build? I check this site daily so I would be well aware of any updates. Just something to ponder on.
Thanks again for all of your great work.
I'm not sure I understand what it is that you are saying. This ROM is for the Minix Neo X8 and X8-H. I was unaware that this rom would be compatible with the X8-H+(plus)... I would not try to flash this rom on the newer X8H plus as you may likely brick your device.
I may be wrong on this but I know for a fact that the differences are enough to matter.
Originally posted by glockman4519 View PostI'm not sure I understand what it is that you are saying. This ROM is for the Minix Neo X8 and X8-H. I was unaware that this rom would be compatible with the X8-H+(plus)... I would not try to flash this rom on the newer X8H plus as you may likely brick your device.
There are currently 2343 users online. 0 members and 2343 guests.
