hello friends I want to thank you for this wonderful rom finlees development I have a question that I would like to clarify is that I have a usb lan and I connected and it works well the problem is that after a few minutes the screen freezes nose if it is normal or simply not work ethernet someone could help thks.
MK808 Android mini TV Player - Finless 1.5A Custom ROM
ethernet screen freez
Hi Bob
Thanks for your wonderfull job ! I've just installed the finless 1.5a and it world pretty well ! Big wifi improvements, i've run some 720p vidéos as well through cpl and ethernet USB adaptator...
Does any of you tried onlive on this device ? I'm curions to see how it works on a GV-20 / mk808 device ...
Big thanks for your work again. French cable tv app for android called canal touch works awesome too, as xbmc néon
I've been using Finless 1.5a for a week now and overall it's working great.
WiFi still drops to 5MBps though. I've been trying to conenct an external USB->WiFi dongle based on rainlake's instructions but with no lack. Has anyone else connected USB->Wifi, does it work better that internal wifi?
How did you succeed?
Originally posted by nasosal View PostI've been using Finless 1.5a for a week now and overall it's working great.
Rainlake helped me get the rtl8191su driver for my old usb wifi (300Mbps), and it works flawlessly on 1.5 and 1.5a.
It sees a lot of neighbor access points. Streaming HD mkv videos from my NAS is smoother than the usb-to-ethernet adapter I have. Thanks to rainlake.
FYI, my wifi router is Belkin F7D4301v1 sitting just one meter away.
Originally posted by bthoven View PostOn 1.5a, internal wifi still drops to 5Mbps from time to time; so I totally give up.
I have got also a rtl8192cu chipset USB->WIFI dongle. Can you please verify the steps cause somehow I cannot get it work.
1) put rtl8192cu.ko (or relevant .ko) in system/lib/modules
2) make proper permitions and owner root:root
3) disable wifi
4) insmod rtl8192cu.ko (or relevant .ko)
5) check dmesg, everything is OK
6) put dongle on USB powered Hub
7) enable wifi
If you want to get the dongle work after boot,
8) rename rtl8192cu.ko (or relevant .ko) to rkwifi.ko in /system/lib/modules
Did you have to do anything to wpa_supplicant or any other file? init.rc?
NEW - MK808 Android mini TV Player - Finless 1.5A Custom ROM
Hi Nasosal,
Very simple steps:
1. Disable wifi
2. Use rootexplorer to copy rtl8192cu.ko into the folder where rkwifi.ko resides. Change permission as you did
3. Rename original ko file to other name, and change your new ko file to rkwifi.ko
4. Plug your usb wifi, no need to reboot
5. Turn on wifi
As simple as that, no reboot, no insmod.
also problems with droidmote.
Originally posted by garyb View PostI just received my MK808 and flashed the Finless 1.5a ROM. I'm trying to get Droidmote to work but so far without success. The Droidmote FAQs indicate that the uinput.ko module has to be loaded for the server to work. I have search the file system with Root Explorer and the uninput.ko is not present on my device. From previous posts, it seems some have been able to get Droidmote working. Is there an uinput.ko available How did those of you with working Droidmote get it to work?
Thanks,
Gary
Originally posted by lang View PostFirmware is a bit of code that controls hardware.
I never seen firmwares stored outside the acctual hardware.
So no u cant change the firmware.
But u can add drivers to the system.
Follow this
Originally posted by joe9003 View Postwifi is totally fixed with an antenna upgrade you don't even need to use a good antenna to do it a peace of wire will do the trick, its very easy to fix takes about 20 minutes depending on how tidy you want it.
ive had this running 12 hours now at 65mb no drops on 1.5a rom.
the stock antenna is a load of rubbish even unsoldering were i marked could improve the signal, better to remove the thing all together and place a simple wire on the ant pad.
Guys uinput.ko is in the ROM. Many have said droidmote works!
Now, I will tell you if you found a droidmote server APK from a pirate site or not paid for, it WONT WORK! The developer has put a lot of effort into protecting his APP. So only way is to buy it!
There are currently 2169 users online. 3 members and 2166 guests.
