I've put together something special for ENY EM8 (square) and K200 T8 (rectangle) boxes. It's called the Megatron ROM because... well... it's mega with over 40 Android apps included. The name Megatron ROM was also chosen because I hoped this ROM would transform the S802 TV box landscape and bring the joy back to Android OS.
Watch the Megatron boot video on YouTube here (Thanks @coolwave_kodi)
Read installation instructions in post #2 very carefully! To download please visit http://mega-tron.tv and click the Download button for either M8 or T8.
If necessary, please use the following alternative links to download:
UNZIPME.M8-Megatron.zip
UNZIPME.T8-Megatron.zip
UNZIPME.Megaton.EMU-Installer.zip
This ROM is based on Stane1983's ENY EM8 build Version 2014-09-03 which includes:
(http://www.freaktab.com/showthread.p...e-by-Stane1983)
- Kernel 3.10.53
- Rooted (SuperSU included)
- Based on Amlogic SDK from 2014-08-23
- XBMC 13.2 included
- Wifi/Bluetooth/Ethernet working
- Real sleep
I have added the following changes to the original build:
- Edited getprop to allow both eny_em8 and k200 devices
- Debloated useless stock apps apps (e.g., live wallpaper)
- Deodexed app, priv-app and framework folders
- Added dozens of apps to pick and choose from
- Offer choice between XBMC 13.2 or Kodi 14.1
- Included several popular launchers
- Extract tar.gz used to install sources for XBMC and Kodi
- Custom Megatron boot image and boot video (Courtesy of @coolwave_kodi)
- Set persistent timezone GMT via build.prop
- Silenced Android Effect_Tick system sounds
- Mapped conf file for both M8 and T8 remotes
- Custom Megatron MBox settings and launcher
- New default_wallpaper via framework-res
- Enabled init.d support via boot.img
- Added Xbox and PS3 KO modules (not tested)
I also created an Emulator update that can be flashed over-top of either M8 or T8 ROM. This update will install roughly ten game console emulator and game pad controller apps. This flash is also available at http://mega-tron.tv (see alterative link above).
When I look at other ROMs posted by the likes of Finless Bob and others, I recognize there are many more things that could've and perhaps should've been done to make this ROM better. I'll consider making further revisions to the ROM according to the feedback received.
There are two bugs that I am currently aware of: 1) Clock doesn't work on T8 boxes and 2) On-screen keyboard defaults to Chinese language. Fixing the clock issue could be fixed redoing Megatron with a T8 build as the base - but I'd much rather someone tell me how to modify the Stane ENY EM8 build to get the clock working on T8. As of now, I don't know how to fix the on-screen keyboard issue.
I hope this ROM is well received. Please send me a PM if you have concerns about it.
This project would not have been possible without the generous contribution of several important individuals. Thanks to Stane, Tony, Corey, Mike, James, Mark, Jason and Bob! Web design by http://sysclonedesign.com
Follow @megatrontv on Twitter at https://twitter.com/megatrontv
