send me a PM and i'll give you a link to v2. i added a couple more boxes and maybe yours is one of them
Megatron ROM for ENY EM8 and K200 T8 boxes
it could be related to tcp/ip fix in v2, you might want to try the update
truthfully i'm not an expert at home networking but i've had my share of issues with samba. i also think plex server is a good way to share videos over home network
Originally posted by whyze View PostHeya gang.
I'm new to the EM8 having just picked up the unit this week.
I've gotten the Megatron ROM installed without issue but am having some performance issues with most of my movies.. here's the skinny:
try putting just recovery.img on your sdcard and then do toothpick method
Originally posted by mahsidi View PostI flashed this firmware and although its nice and works well I want to flash another rom,
Toothpick method, or entering recovery mode via toothpick or the "reboot app" won't let me enter it.
Any help? or am i stuck with this rom?
thanks
not sure what can be done here. might be best to flash a different rom, sorry to say
Originally posted by boleyu View PostHi all, I installed Megatron ROM on m8 box.
works great and installation was easy following instructions.
the only issue I have is that blue light comes on during start then goes off, which is not a big deal.
I need to temp hide root in order to run D3GO app, used rootcloack, hide my root apps, all showing that root is hidden, but when run D3GO app message shows: to watch program you need to temporary or permanentl unroot, VMX:andriod_47
cah I get some assistance with this
send me a PM and try v2 of M8-T8 rom
Originally posted by Kellyj19785 View PostHi,
Im trying to install your rom on my m8 square box
Formatted sd and copied 3 files across,
Boot to recovery and the install starts, but seems to freeze after a few seconds.
Tried to go manually into recovery and install from ext, select file and then it hangs.
Also tried re downloading rom and trying again.
Can anyone help pls?
hi morrig,
chrome browser is one of the apps included with megatron rom. you should see it there after flashing (remember to wait 10-15 minutes)
must admit i'm guilty of removing wallpaper related apps. not sure if you can reinstall those manually
never heard any problems with usb deviced before. not sure what to say about that one
if you like mediaman, super... sounds like a good one!
Originally posted by morrig View PostTriedTried today, installed on M8N with wired internet ok, ran into a few problems with some playstore apps not suitable for instance Chrome browser not even in playstore but installed via Aptoid and after installing a wallpaper changer and went to click on it says not installed.Having a few hours of use wireless usb mouse froze rebooted and it happened again within minutes,so restored Mediaman rom ,been running for a month with no problems.
Megatron rom flash perfectly after.
(m8 square)
hey guys is the new version of the rom out? What i want to know, does the new rom overcome the 30mb capp on the wireless? ive been stuck on that even with finless bob rom and your first rom. if your rom fixes that issue then that will define which rom i will use out of both, both are really amazing roms tho, thanks alot
i went back to bob finless rom to do some tests for wifi guys, took some nots and reflashed megatron rom, it flashed but not im stuck on the megatron logo at the start, ive given it 20 odd mins and it hasnt progressed, any ideas?Last edited by cmac86; 24 March 2015, 21:02.
Hey guys just installed the latest update of the rom and with in the first 35/40 mins here my wifi connection turned itself off 4 times. I have to go into it manually and turn it on again, ive done various speed tests and ive come up shorter than i had on the previous rom, apart from that the rom ran great, very smooth, Im going back to the first release as its the one that worked best for me, thanks alot.
Originally posted by cmac86 View PostHey guys just installed the latest update of the rom and with in the first 35/40 mins here my wifi connection turned itself off 4 times. I have to go into it manually and turn it on again, ive done various speed tests and ive come up shorter than i had on the previous rom, apart from that the rom ran great, very smooth, Im going back to the first release as its the one that worked best for me, thanks alot.
Hi All, ran into this while browsing the net. Didn't find any posts here referring to it, thought I'd share to see if anyone has seen it before or tried it out.<br />
<br />
I'm at work so I can't exactly test it, so if anyone is going to try it do so at your own risk I don't want to be held responsible for any bricked boxes.<br />
<br />
http://chinagadgetreviews.blogspot.c...k_59.html#more<br />
<br />
update: installed successfully on M8N. So far seems smooth, not a lot of junk installed. haven't played too much with it but, looks good to me so far. Comes up as KOT49H 20150122 test-keys in settings if that matters<br/>
There are currently 2067 users online. 1 members and 2066 guests.
