Megatron ROM for ENY EM8 and K200 T8 boxes
    Hello Guys I have the OTT M8 and have flashed Most Roms and none of them have the Wifi working? Does this have the Wifi working on it and where would i get versions 1,2 and 3? Thanks
      The factory rom I just posted has the wifi working, for the Megatron V1,2 and 3 goto http://mega-tron.tv/ depending on which version of the m8 you have you may get one to work. (eM8 M8n M8)
        Thanks smspop your the 1st Person to actually respond and try to help me after posting a few times in here and other forums. I've just tried every version of Megatron V1 doesn't load and just a black screen, v2 and v3 load but no Wifi. I might have to get an Ehternet cable and hope that the Wifi isn't the only problem on the Network card and the Ethernet Port Works. It's trying to search for Wifi but not finding anything and all my other devices work so it's not my Router or anything. Cheers Marti
          If you put V2 on(no wifi) then put the factory recovery zip onto usb boot into recovery from TWRP recovery on a SD card, once there click install and install the zip from the TWRP recovery menu, when its complete boot to system you will have the mega image without the bootlogo or splash with wifi working.
          you need a mouse pluged in to do this.
          Let me know if you need the TWRP recovery files for SD card and I'll post them on Mega.
            Really Appreciate your Help smspop. I've been and bought a Cat 6 ethernet Cable and when i've tried to flash Mega and it Finished i got a Screen with lines going across the tv. This is bar far the Worse expereince i've had flashing droids. I've even flash a different Rom and get the same result. Any Ideas? I've spent Hours on this box and i don't want to give up but i'm getting close! Help!!
            Thanks in Advance
              What Variation of the M8 is it?, (M8, EM8 M8N or M8s) have you a link of where you bought it from
                It Says M8 on the Bottom and OTT on the Box. Here is the Link:
                http://www.****.co.uk/itm/3911673179...%3AMEBIDX%3AIT
                Its loads the Flash Screens up fine and the Recovery droid looks fine aswell.
                Cheers Fella
                  Have you any idea of the original factory Rom that was on it
                  EG: K200
                  4.4.2
                  Build no: KOT49H.20150519 TEST KEYS
                  KERNAL VERSION
                  3.10.33
                  TANWEI@TANWEI #5
                  MON MAY 14.48.56 CST 2015
                    That was exacty it what you have said there. I remember it was as i remember the date 14th May and all the other looks very familiar.
                      Have you tried the factory rom I posted
                        It's still doing it but now if i leave it a while the rom loads up. Looks worrying at 1st. I tried the Factory Rom before all this started. Speed is great on Cat 6 ethernet Cable. I've resolved a Slow Wifi connection i hade from out of the Box but by god its not been a good expreince. I guess i'll have to live with the full lines on 1st load up. Very Strange. Hope it's not the Signs of something bad going to Happen. I've got the M8_mbox-GEv2 rom on.
                        Thank you very Much for your Help. I tempted to leave it but now i have a dilemma as i paid for Justme roms last night and i've got their latest Rom to flash. I thinking just leave it if it's working. I think i'll buy the Nvidia Box when that come out. It's a Best have you seen it?
                        No Blue led on the front which is a shame as i like it.
                          The Lines you are getting on boot might be caused by the boot animation have a read at the post below, it quite easy to change, a quick google for bootanimation.zip files should uncover some, the just use es file explorer to copy the zip to /system/media on the internal memory of the device remember to enable root and hidden files from the tools menu in esfile explorer.
                            Done a fresh install of v3 and my earlier problem has gone which is great. I do get kodi crashing out on occasions tho when launching the app. I also miss the Xfinity launcher.
                            Thanks for the rom 😊
                              I've followed all the instructions to the letter but it just won't flash my M8 box. Have tried everything but the rom seems to start flashing-Android symbol with moving symbol, but then after about 20 seconds it goes back to the start again. There is no dialogue at all during the process, apart from select the Megatron file from install from Ext
                                Hi, can you help your MEGA link is stuck on 0% :-(
