Megatron ROM for ENY EM8 and K200 T8 boxes
Hi I updated my OTT M8 to Megatron V3. I have 2 issues:
1. volume up and down no longer works. I looked into the configuration file for the remote in system/etc/remote.conf and it was the same settings as V1 which was working. e.g. 0x11 104 and 0x4c 109. I know that the IR codes are working because I mapped them to 116 which is the android code for the Power button, and they both turned off and on the box. This leads me to think that the rom is not correctly configured to accept these codes.
2. I am not able to reset to recovery using the toothpick method. I had the same issue in V1 but it had the update & backup recovery app.
Anyone else having these issues? Anybody find a solution.
Thanks,
Same box, and volume works ok on mine.
I did a recovery by reinserting the SD card, and then toothpicking. It actually did an update, and installed kodi on the update instead of XBMC 13.2 and a few misc. things. Maybe worth trying that for you?
Also, and I don't recall seeing this on the first boot; there is now Transformer recovery option in apps.. I don't think it was there first time around.
There are two things that DON'T work - Mobro says it can't connect, and HDCinema also not working now. The latter I don't care about since it's another pay app., but Mobdro not working is disappointing. It works fine on a stock firmware Amlogic S805 MXq variant Same apk does not work on the OTT M8, AmLogic S802 box.
In fact maybe someone else can help on that issue -Mobdro not working...It works fine on a stock firmware Amlogic S805 MXq variant Same apk does not work on the OTT M8, AmLogic S802 box. Any other mega-Tron users with the OTT M8 box have that problem? It's weird because originally HD Cinema worked. At that time, I didn't check mobdro as i had no idea what it did, and I'd become nervous since Google managed to get my credit card number from me; and then HD Cinema wanted to charge me. I stopped clicking things until I knew what they actually were.
markedman, thanks for the advice. I kept trying and eventually it worked. Not sure why it did that but whatever.
I have another issue now. I updated my friends to the latest V3 for megatron but he lost wifi. It won't even turn on in the android settings. The original build was KOT49H.20150601 test-keys. I think that this box is really new (from this month) so they might have changed the wifi chipset causing it to not work with megatron.
I tried flashing all of the different roms that I could find e.g. finless, justme, eny mediabox standard roms, etc. but none of them work. Wifi is still not working in any of them.
Anyone know where I might find the original firmware so I could go back to it? Should I contact OTT directly?
Thanks,
P.S. never used Mobdro so I can't really help you there. Sorry.
hi there im also having a problem with v3, with was the same on v2. I link my m8 box to my pc over wifi but v3 and v2 dont give me movie covers in kodi via a smb connection. Need to go back to V1 but when flashing via recovery i get a msg saying that i cant downgrade. how can i get back to v1 where i did not have the issue
I'm also having the same issue with no wifi from build: KOT49H.20150519 test-keys.
Kernel version: 3.10.33
tanwei@tanwei #5
Tried flashing back multiple ROMS including stock but it seems to be stuck not working.
Is there a baseband that i can flash to the device that might get this working? Really hard to find anything on fixing this issue :-/
nub here, question, i installed v1, after that installed, v3, im not seeing the xunity launcher, has that been dropped?, megatron is great, thanks to all who made it happen, installed this on a friends M8, when the software on it went south, blue lite is off now when the box is off, and you can turn it on and off with the keyboard now
Originally posted by Rezil View PostI'm also having the same issue with no wifi from build: KOT49H.20150519 test-keys.
tanwei@tanwei #5
Takes about 5mins to fully boot after recovery so be patient.
Model Number
K200
Android version
4.4.2
Build
KOT 49H.20150626 test-keys
KernEl Version
3.10.33
tanwei@tanwei: #6
Sat Jun 13.10:17:07 CST 2015
(https://mega.nz/#!DhgBBaIQ!IZHBB7A3-...g3wri5QBjCPCbA)
You can also recover from twrp on sd card and zip on usb, just select install in twrp and select the zip file.Last edited by smspop; 03 July 2015, 22:50.
There are currently 1831 users online. 0 members and 1831 guests.
