Megatron ROM for ENY EM8 and K200 T8 boxes
Works now. I want to mention that vdubt25 mispronounced a name in the video. Stane1983 built this Android ROM last year and Megatron merely extends what he did.
Thanks again Stane(espresso shot)
Originally posted by tup14 View Postlol! That's what happens when u get used to your own site.
https://www.youtube.com/watch?v=aHYXDBerzrI
Originally posted by djpeterdj View Postmine is working flawlessly. would like to control it with my phone, but my airmouse works without any lag...
Now if this is a problem with the m8 ROM or the config of the box is still a mystery.
I tried the new Rom from Matricom and I have seen no improvement so went back to the M8 Rom.Man of leisure!
Hi szander, thanks for the update. I understand the lbrtmp is related to live tv, but I'm not sure what you mean by "the data folder wasn't created". Maybe there's something you had in a previous rom that isn't included in megatron.
Originally posted by szander View PostThanks superfreak 79 for the fabulous M8 Rom,another issue besides the others already reported is that I couldn't update the lbrtmp library,the data folder wasn't created, so some live tv streaming channels can't be watched. Thanks.
Hi tup14, it sounds like this ROM is not fully customized for the box you're using. Try manually wiping from recovery and reflash. If that doesn't fix it, then I doubt it will be solved without a new custom build for that particular box - which is something Matricom should be doing
Originally posted by tup14 View PostI have a Matricom G-Box Midnight Q and there is a definite problem with the remote shut off button and also the app Reboot Manager that shuts down the box. The shutoff just reboots the unit and no way to turn it off. I have three members at my site and all have the same problem.......
Originally posted by superfreak79 View PostHi tup14, it sounds like this ROM is not fully customized for the box you're using. Try manually wiping from recovery and re-flash. If that doesn't fix it, then I doubt it will be solved without a new custom build for that particular box - which is something Matricom should be doing
What is strange was that the first time I installed M-8 Rom I could turn the box off and on with the remote button..there wasn't a command present but wold just shut down and restart by clicking the on button.
Others as posted here were getting that black screen and would have to unplug the power cord to get it to restart.
After I did that test Rom I had the same problem so as you know I decided to go ahead and install the Matricon's new rom. but seen no difference with Kodi and had issues with other things. There format sucks so decided to go back to the original Rom-M-8 and that's where I'm at now and except for having to leave the box on it works better then anything else.
Yes Matricom should be doing a lot of things but not the band aid fix they came out with
I replied to another post here today and really would love to see what the top three box's are used here among the members. It's really hard to decipher from marketing ploys to what actually is a good product.
A good poll would really help on deciding what my next box will beMan of leisure!
Originally posted by superfreak79 View PostHi szander, thanks for the update. I understand the lbrtmp is related to live tv, but I'm not sure what you mean by "the data folder wasn't created". Maybe there's something you had in a previous rom that isn't included in megatron.
There are currently 1991 users online. 1 members and 1990 guests.
