Pipo M6 Max
Originally posted by mnunyez View Postrom installed and running. In the first start and after an hour with the flash on, I made the corresponding reset and everything worked perfectly. I keep trying.
Never let the flash led on during one hour... make a reset after max 10 min !
I have noticed that this tablette doesn't reboot correctly with charger plugged, especially during flash process.
Charge the tablette 100%, disconnect the charger, then flash the rom without charger.
Anyway, happy to read is working ! Good testing.
Just to know, did you let the changer plugged during the flash process ?
Slowry, I noticed you have a recovery.img in the preinstall folder. Is that TWRP or CWM?
I've already asked Abdul_pt to do a TWRP for this ROM, but let us know if this is one you made...or a generic one.Randy
Also, did the SDK you were using have most of the apps up to date? On the M9 Pro ROM, I've had to add some things that were missing.
Testers...can you check Location Services, Exchange Services, Download Manager and see if they are working? If not, I have some patches to add. Otherwise I can leave well enough alone.Randy
Originally posted by rrileypm View PostSlowry, I noticed you have a recovery.img in the preinstall folder. Is that TWRP or CWM?
I've recompiled all the android sdk and updated gmail2, google service, playstore. I didn't find more updates.
OK...Abdul is making us a custom one just for the M6 Max based on your kernel/recovery.img.Randy
I'm waiting on Abdul_pt's TWRP recovery to finalize everything.
The updated version will have:
Root with latest SuperSU (Chainfire)
New boot screens (by Tattman65)
Google Play Store fixes to increase app compatibility
Edit to allow for SD card write permissions
Many more parameter file choices in 1gb increments
Some debloating of usual unnecessary apps
TWRP recovery
Increased Ext4 system.img size to fill the whole system partition instead of leaving wasted space
Multi-User support activated without needing an Xposed Framework module to do it.
This already has root, init.d, busybox, preinstall...but since my script/kitchen adds it automatically, I will just let the script run and update everything.
Slowry, I'm a little confused about the size of the graphic in the kernel. This tablet has a 2048x1536 resolution, but your graphics are all 1920x1200. I made the kernel brand 1920x1200 to prevent conflict, but I'm wondering whether the boot animation will run correctly at 2048x1536...we will have to test that.
Stay tuned, I should be done tonight.
If Abdul_pt doesn't get the TWRP finished, I will just post it here for everyone to install manually from the flash tool.Randy
Here is FreaktabROM v1.0.0 with the above changes:
FreaktabROM v1.0.0
Please test to see that everything boots and works OK.
This version does not contain a new TWRP recovery. We will add that when it is available.
Thanks Slowry, for giving us an excellent base to work with.
Enjoy!!!!!!Randy
There are currently 1635 users online. 1 members and 1634 guests.
