If you need firmware from Finless, here is the link to it, I uploaded the firmware to another store.
WARNING, NEWS, and ROM - New model UG802 different wifi!!
clone ug802
Originally posted by Finless View PostThanks to Ken and his DUMP I made a stock ROM for you clone guys.
This is not rooted or anything. Just a stock ROM for you.
ROM DOWNLOAD -> CLONE UG802 Stock ROM (228 megs)
Thanks.
I have this minipc: http://www.iconbit.com/products/107960/
This is a clone of UG802 v2 (with reset button)/
I flashed my device with last allminipc.com ROM and did that hardware mod: http://www.freaktab.com/showthread.p...l=1#post106406
But now i have unstable WiFi connection (0.1-10Mbit/s).
So, I need help: please tell me how can I change resolution to 1080p in stock firmware (stock firmware shows stable and fast connection, but bad resolution=1280*672)?
Thank you people! I managed to revive my mini pc labeled T002 V2 20121207. I used the firmware that was posted the first time by the user Mtype101 (post 218) and everything works perfectly. I just have one question: is there a way to make this work at HD Ready resolution (1366x768). Sorry for the bad English!
Originally posted by etna0815;a s have found the difference at wifi connection on UG802 V2 clone boards (MiniTV SW601...)
There is an aditional MOSFET (blue) that controls the power supply of the wifi module. After adding a solder blob that bridge this MOSFET wifi works with UG802 Stock and other V1 kernels.
[ATTACH=CONFIG3665[/ATTACH]
For all user that have flashing problems try other Loader. At my board only 1.11 and 1.28 works.
What pins did you solder together?
Thank you
Hey guys,
I have a MK809 with PCB labeled with T002 V2 20121207 but it has an RTL8188ETV wifi chip. Which ROM is suitable to me?
Thanks in advance.Plasma: Panasonic TX-55ST60E
HTPC: LC-Power 1320mi :: Sapphire PURE WHITE Fusion E350 :: 4GB DDR3 :: SSD Corsair Nova 2 [SO] :: 4TB [Storage] || Android PC: Minix X5
powered by Win7 :: XBMC Gotham :: SABnzbd :: CouchPotato :: SickBeard
I badly need the ROM DOWNLOAD -> CLONE UG802 Stock ROM (228 megs) from the 3rd post ,
my ug802 is a version2 , the one with the reset button,
I've flashed about a dozen different images , they all work but none have working Wireless (stuck at turning on wifi)
It could just be the wireless is broken but I need to try this rom
Could someone kindly reupload the Rom
There are currently 2140 users online. 0 members and 2140 guests.
