I've got a second hand UG802.
The info screen says:
- Android 4.1.1
- Kernel 3.0.8+
- Build Number
RK30_ANDROID4.1.1-SDK-v1.00.1015
rk30sdk-eng 4.1.1 JRO03H eng.ant.20121025.095326
Everything works well with stock ROM, anyway I'd like to install Finless ROM 1.7 but I'm a little bit worried about the problems with wi-fi on some version of the mini-pc.
I've tried to open it to check the PCB but I wasn't able to do it (...), so I cannot check which version I own.
Could someone figure out the UG802 version from the info or, if it is not possible, how to open the case without break it?
Thank you all!
Roberto
