CWM recovery for rk3066 devices.
Originally posted by Craxx View PostMy Device: T-R42
ROM: Wasser ?????
Peripherals: 5Port USB-2 Hub : Logitech K700 Keyboard : Buffalo 1TB HDD : 32 GB MicroSD : Wireless Xbox360 Controller : 5amp switch mode power supply
Originally posted by pulsar View PostHi All,
I recently flashed my MK808B using Finless 1.6 (Thanks to Finless). Now I want to flash the CMW Recovery image but I'm not sure wich flash-tool to use. I've RKBatchTool and ROM Flash Tool on my pc. Can I use one of these?
Re: CWM recovery for rk3066 devices.
Originally posted by pulsar View PostI thought method only could be used when original fw was installed. But anyway I'll try, thanks.REMEMBER, YOUR FEEDBACK IS VERY IMPORTANT TO US.My devices:
Originally posted by leolas View PostOk you are right, but finless recovery is the same than origiginal one, so you can use first post mode.
I've small remark regarding Finless 1.6
When I monitor system hardware, cpu speed shows incorrect 1006 MHz. Original Rom showed correctly 1600 MHz. I used PerfMon v1.10 app (http://forum.xda-developers.com/show....php?t=1933284)
With same governor?
Finless roms have the same kernel than stock.
I will try that appREMEMBER, YOUR FEEDBACK IS VERY IMPORTANT TO US.My devices:
I have made no changes that would cause clock speed to change! It's locked in the kernel. Unless your using some other kernel?
Originally posted by Finless View PostI have made no changes that would cause clock speed to change! It's locked in the kernel. Unless your using some other kernel?
What I mean is that PerfMon app detects lower clockspeed, but in reality clockspeed is correct. When I used original stock ROM PerfMon app detected correct clockspeed. I was just wondering how this came to be.
This could be caused by some optimizations who make some process logs disappears. Maybe this apk like other look in those logs. I am not sure, but i bet for that.
But I am sure that Bob Rom feels faster than stock.Last edited by leolas; 15 February 2013, 12:04.REMEMBER, YOUR FEEDBACK IS VERY IMPORTANT TO US.My devices:
Gapps? Why? I usually flash gaps in cm cause we had not google play access. In our Roms we have google play.
Actually we have not got any flashable full roms by cwm. I hope we have them soon. By the moment cwm recovery is the easiest way to have full nandroids backups and restore.
I dont know how make a full Rom zip flashable by cwm.
I use cwm to flash a zip with kernel following fun indications to test my own compiled kernels but it is the only zip file I tested actually.Last edited by leolas; 15 February 2013, 12:05.REMEMBER, YOUR FEEDBACK IS VERY IMPORTANT TO US.My devices:
There are currently 2036 users online. 1 members and 2035 guests.
