CWM recovery for rk3066 devices.
Re: CWM recovery for rk3066 devices.
Originally posted by strix View PostHi there.
Installed cwm but i can not navigate in the cwm meny. I try to use blutooth mouse no luck and also RK remote.
I use MK 808B
Please help me out.Last edited by leolas; 28 March 2013, 21:31.REMEMBER, YOUR FEEDBACK IS VERY IMPORTANT TO US.My devices:
Originally posted by leolas View PostWith rkremote or bt mouse is imposible, cause the application and bt are not enable, you need a usb device to control it, radiofrequency devices works too.
I'm not the lowest of the low, but I am the slowest of the slow (49.5 mpg over 42k miles in Scion xB)MK808 w/Omegamoon kernel, CWM recovery, & Finless 1.7 ROM
I allways use full size port, with a hub connected on it. Only use otg for abd or flash.REMEMBER, YOUR FEEDBACK IS VERY IMPORTANT TO US.My devices:
B13
There are several CWM for rk3066 devices. I have used the generic one for the B13 minipc. I have installed using the "update.zip", and the message successfully installed appeared. But When I reboot into recovery the CWM menu does not come up. It reboots only in stock recovery. Which is blue screen.
I would like to try the custom roms to see if they work on this minipc, but I would prefer to make a backup first, since I have already tried the 1.5 for mesay U2C but no wifi or bluetooth.
I would appreciate some help.
BRLast edited by soliveira; 01 April 2013, 16:18.
I've been using CWM recovery for my UG007(II). The other day i wanted to make a backup and everything seemed to work except it got stuck at the end when calculating the MD5 (waited at least 30min, nothing happend). I've read this was a known bug in an older version on CWM (i read it in post from a while back about different devices).
But since i seem to have the same problem now i was wondering if i could use the MX1/2 CWM recovery.img on my UG007 since the hardware is the same. The reason why i'm asking is because, since the hardware is the same, i also expected the CWM recovery.img to be the same, but they are a different size.
Of course if i flash a MX1/2 ROM (without replacing the recovery.img with the CWM one) i would also have the recovery.img for the MX1/2, so my gut tells me it should be no problem. But since CWM seems to be my safety net in case of bad flashes (or just incompatible ROMs/kernels), I dont want to mess with it without being sure.Thanks!
p.s. Everything else in CWM seems to work just fine. Flashing ROMs or just kernels. Clearing the caches and stuff like that, rebooting. That all works.- UG007-II with Finless iMito MX1/2 1.7a ROM and UG802 2Dark4U 1080p overclock kernel and USB WIFI dongle.
- MK808 with Finless MK808 1.7c ROM and 2Dark4U 1.4 MK808 1080p overclock kernel.
- MK908-II: XBMC full 1080p playback with a 1080p kernel HERE
Originally posted by Abducted View PostI've been using CWM recovery for my UG007(II). The other day i wanted to make a backup and everything seemed to work except it got stuck at the end when calculating the MD5 (waited at least 30min, nothing happend). I've read this was a known bug in an older version on CWM (i read it in post from a while back about different devices).
p.s. Everything else in CWM seems to work just fine. Flashing ROMs or just kernels. Clearing the caches and stuff like that, rebooting. That all works.REMEMBER, YOUR FEEDBACK IS VERY IMPORTANT TO US.My devices:
I'm new to these sticks ...
so please i need some help from you ...
I bought this stick:
http://cgi.****.de/ws/****ISAPI.dll?...d=469919120275
in the settings there is a "rk30sdk".
but with the images from this post
I have realized that there is a "clone V1 mk808b"
So which I need CWM.zip?
- MK808
- MK808B (RK903)
- MK808B (MT5931)
I want to try some other roms, but I want to make a backup
thx vip
thx vipREMEMBER, YOUR FEEDBACK IS VERY IMPORTANT TO US.My devices:
Originally posted by leolas View PostMk808b(mt5931)- UG007-II with Finless iMito MX1/2 1.7a ROM and UG802 2Dark4U 1080p overclock kernel and USB WIFI dongle.
If there is a mediatek chipset, thats is the cwm image, i didnt test it, but I think that everyone must work, WiFi is not used in cwm. When I will return home I will test.REMEMBER, YOUR FEEDBACK IS VERY IMPORTANT TO US.My devices:
@Abducted
yes if you look at the **** site it hasn't BT.
but my stick has BT and it works fine
So I take Mk808b (mt5931) which leolas meant?
My stick looks like this:
Compara las mejores plataformas de trading, plataformas de trading de criptomonedas y robots de trading. Obtén reseñas detalladas e información para elegir las herramientas adecuadas para tu experiencia en el trading.
thx
vip
thx
vip
Here is the link to cwm download files:
http://androtab.info/clockworkmod/rockchip/rk3066/REMEMBER, YOUR FEEDBACK IS VERY IMPORTANT TO US.My devices:
There are currently 2540 users online. 0 members and 2540 guests.
