When I was using a ROM for the Archos 80 Cobalt created by supersport900 he included a newer version of CWM that used the incremental backup but I found that after a backup, when I went to restore, it didn't seem to restore the data image and I ended up going back to an earlier version to get it to work correctly.
CWM recovery for rk3066 devices.
Originally posted by atac5922 View Post
When I was using a ROM for the Archos 80 Cobalt created by supersport900 he included a newer version of CWM that used the incremental backup but I found that after a backup, when I went to restore, it didn't seem to restore the data image and I ended up going back to an earlier version to get it to work correctly.R-TV BOX S10, Beebox N3150, Chuwi Hibox, Nvidia Shield, A95X Max
Originally posted by bluesmanuk View PostDoes your CWM backup contain a folder called 'blobs' by any chance?
Originally posted by atac5922 View PostNope, no 'blobs' folder. i don't think its v6.0.3.1 does incremental backup. i still get the same folder and files everytime i backuped. the files are all similar in sizes.(bigger if i install new apks and smaller if uninstall some apks)
In my back-up folder I have the following files
.android_secure.vfat.tar
.android_secure.vfat.tar.a
boot.img
cache.ext4.tar
cache.ext4.tar.a
data.ext4.tar
data.ext4.tar.a
kernel.img
nandroid.md5
recovery.img
recovery.log
system.ext4.tar
system.ext4.tar.aR-TV BOX S10, Beebox N3150, Chuwi Hibox, Nvidia Shield, A95X Max
boot.img
cache.ext4.tar
cache.ext4.tar.a
data.ext4.tar
data.ext4.tar.a
kernel.img
nandroid.md5
recovery.img
recovery.log
system.ext4.tar
system.ext4.tar.a
My subsequent backup of Finless 2.1 have all the same files(13 files) and also cannot be restored.
I also cannot install CWM by using the update.zip from sd-ext method.
GOOD NEWS is I found out i could install cwm from usb stick using update.zip method.
There is a pop up message asking if i want to copy to sd-int. select yes and after that another popup asking if i want to install update. It installs and reboot to CWM.
So those people who cannot install from sd-ext can use this method from usb stick too. No need pc too.
UPDATE:
MK808 stock rom successfully restored after reflashing to Finless 2.1 and stock rom backup with missing cache, nandroid.md5 and recovery.log files. This is how i did it:
1. Have to reflash to Finless 2.1 but using 'parameter original' file-this is important
2. Installed CWM using usb stick method
3. Reboot to recovery using Petrus reboot
4. Restore stock rom with an 'empty' nandroid.md5(your method) and without cache and recovery.log files
It will restore boot.img, kernel.img, system.img. At restoring data files it stopped part way and the CWM menu pop up. Waited a few minutes and seeing nothing happening selected GO BACK and Reboot system.
The stock rom booted up without any problem. Only thing is the apks 'short cut' in the start screen is missing. I supposed this is because data restore failed. But at the apk drawer the user installed apks are there and functioning properly. So it seem only the 'short cut' at start screen failed to restore.
Used it for about 4 hours after restoring and did not find anything wrong with it. So concludes that restore to stock rom is successful even with missing cache, nandroid.md5(original) and recovery.log files.
Thanks alot for your help and method and of course LEOLAS too.
Re: CWM recovery for rk3066 devices.
Originally posted by atac5922 View PostI have the same files too except for cache files, nandroid,md5 and recovery.log for my MK808 stock rom backup done previously which could not be used for restoring back to stock rom after flashing to Finless 2.1
UPDATE:
Thanks alot for your help and method.
Originally posted by leolas View PostThe problem to restore it comes cause the system partition in the stock rom is so big, to hold all the bloatware, games that not work and useless apps, if you want to restore it you need a bigger system partition, but the stock rom is available in update.img stock format. If you want i can give you a parameter file (here is where partitions size are defined) to allow the backup to fit
leolas
Originally posted by atac5922 View PostThe parameter file you said is it same as parameter original in Finless 2.1?
Originally posted by leolas View PostThe mod for the psu is not so difficult, you need a usb wire and the PSU. In the net must be any schematic instructions, I will look for them.
The better way to see if reset button is ok is open the case carefully, the antennas are fragile.
This is usb adapter when usb on tv have to small mA
When i have time i write in english.
Do złacza tv is for tv usb
złącze power is for mk808 power cable
PVR is when your tv have pvr funcion and ther you can insert pendrive to write your tv program.
Do zasilacza is plug to power adapter 2A.
Do huba is when you use hub active. Becouse when you use active hub for big 3,5 hard drive you must use active hub. But when you use them mk808 dont turn off.
MY CX803 is not booting. It has power (i can see the blue led flashing inside) but it doesn't boot at all. no image on screen. not being detected by windows. What can I do?
I put the update.zip from cmw on my external sd card and nothing. No video no image, nothing. But I can see the blue led flashing inside.
If there's anything I can do...
Originally posted by makelele View PostMY CX803 is not booting. It has power (i can see the blue led flashing inside) but it doesn't boot at all. no image on screen. not being detected by windows. What can I do?
Originally posted by leolas View PostI dont have your device, but in mk808b if you push reset button and while it is pressed connect the otg usb to pc, Windows will detect the device in,flash mode, then you need to erase idb and flah the Rom using the flash tool.
leolas
I see the led blinking but nothing, no image, no windows nothing.
here are some pictures of the device:
Sorry I Dont know, maybe someone with the dame device?
Originally posted by leolas View PostSorry I Dont know, maybe someone with the dame device?
leolas
thank you so much for your help. After countless try's I got the windows to recognize this one. (I had to use USB port in the back, so this is the OTG one.)
Now I am getting one error when flashing finless rom 1.7:
When I press erase NAND IDB it says:
ERROR lower format failed
erasing IDB failed
than if i press flash ROM:
test device failed
run failed
screenshot:
erasing IDB failed
test device failed
run failed
screenshot:
There are currently 2417 users online. 0 members and 2417 guests.
