I will try the term emulator method and hope for luck. When I tried it with the latest 4.2.2 on the 808B last week it did not work. I am really not sure why the factories are shipping the roms this way. Not sure what part of the rom they are messing with to cause such difficulties. Not sure how they think it benefits them?!?!
CWM recovery for rk3066 devices.
Originally posted by leolas View PostIf you are root you can install it using terminal emulator and having busybox installed. Look in my post for rk3188 cwm (rk3188 section), you can download the script zip, and try this way. If it doesn't work for you I will try to make new scripts, the cwm recovery.img that you used before the update must work with 4.2.2, only installation is different.
leolas.
It's nice to see the CWM menu but an awful tease that every selection ends in an error.
Re: CWM recovery for rk3066 devices.
Originally posted by Franb94 View PostThanks for the suggestion. Even with this method the same error is constant - "can't find misc" and then "can't mount /cache/recovery/command" and also "can't find misc" with 4 errors "can't mount /cache/recovery/log" "can't open /cache/recovery/log" "can't mount /cache/recovery/last_log" and "can't open /cache/recovery/last_log"
leolas.REMEMBER, YOUR FEEDBACK IS VERY IMPORTANT TO US.My devices:
cwm not controlable on MK802IIIs BT ?
i installed the latest iMito MX2 rom 4.2.2 and like to have a working cwm to backup the stick. I downloaded the cwm from this link.
I extracted the zipfile and flashed it with terminal session into the recovery partition. After a reboot into recovery the cwm comes up but is not controlable with mouse or keyboard. cannot step up and down in the menu ?
who can help ? think I installed the wrong a bug version of cwm. which cwm is the right one for me ?
Have an MK802IIIs with BT and iMito MX2 rom 4.2.2
thanks in avance
Frank
thanks in avance
Frank
Is a good idea too put the remote receiver at least 15 cm from the box, use an extension usb wire or something like that.
Is there any way to modify the generic CWM to work with the new KitKat partitioning?
Sent from my SAMSUNG-SGH-I537 using TapatalkRandy
Originally posted by rrileypm View PostIs there any way to modify the generic CWM to work with the new KitKat partitioning?
help please
I tryed to install cwm. renamed file to update.zip. android find the update and I installed it. but after reboot nothing happend. no android logo no nothing. just black screen on my tv!
what are my options? what I can do now! any tutorial or guide for flashing finless rom now when I done this.
If you are using a 4.2 Rom you can't install cwm following that way, you need to use a pc to flash it or if your device is rooted then you can use terminal emulator, in the rk3188 section I made a guide, follow it.
Originally posted by leolas View PostIf you are using a 4.2 Rom you can't install cwm following that way, you need to use a pc to flash it or if your device is rooted then you can use terminal emulator, in the rk3188 section I made a guide, follow it.
leolas.
I can't find your guide in rk3188 section for installing cwm with pc or with terminal emulator!
Originally posted by prdek View PostDo I need a cwm to install a finless rom on my mk808!?
There are currently 2443 users online. 0 members and 2443 guests.
