CWM recovery for rk3066 devices.
Re: CWM recovery for rk3066 devices.
Originally posted by hwai View PostThank you Leolas, it works.
leolas.REMEMBER, YOUR FEEDBACK IS VERY IMPORTANT TO US.My devices:
Originally posted by kandilak View PostHi leolas nice work!!!
I just want to ask if there is any chance to having a working CWM recovery for Minix Neo G4 108C version.
The existing cwm recovery from here works only on 108A version of Neo G4.
The stock rom for Neo G4 108C is http://www.minix.com.hk/Support/13101717032507.htmlOriginally posted by leolas View PostOk I will do it, but sorry, I will be out of home until Sunday, I will do it then.
leolas.
Originally posted by kandilak View PostAny progress with this leolas?REMEMBER, YOUR FEEDBACK IS VERY IMPORTANT TO US.My devices:
http://www.freak-tab.de/leolas/cwm/g...covery.img.zip
And sorry a lot for the delay, I am getting old, I forgot it completelyREMEMBER, YOUR FEEDBACK IS VERY IMPORTANT TO US.My devices:
Originally posted by leolas View PostHere it is, please try it and tell us if it works:
Originally posted by kandilak View PostTHANKS leolas!!!! it works. Now i have to wait from minix to fix CPU running constantly at 1008ΜΗz
Want to test for yourself?
Try this:
Download cpu no frills, cpu master, or any program to limit cpu speed.
Download antutu benchmark.
Limit the cpu speed at 1008 with cpu master or other, I suggest "no frill cpu.." the better one for me.
Run antutu benchmark.
Take note of the results.
After, limit cpu at 1400
Run antutu again
Compare the cpu puntuations
CWM for MK819/UG008/UG007 with Android 4.2.2
Hi Leolas,
I have been a fan of your work and that of Fun and the community at large. Your instructions have helped me many times. I have never had to ask for anything until now. CWM is a huge help but I can't find a version to work with this device. Stock firmware is here: http://pan.baidu.com/s/1zOOYV
MK819/UG008/UG007 CWM all the same under Android 4.1.1. I just used the UG007 CWM and it was great. The same version does not work with 4.2.2. I have loaded by writing with Finless ROM flash tool 1.37. I had first tried using update method but of course that failed with latest 4.2.2.
Stock recovery just rewrites it without any menu/options.
I would really like to get CWM working on this device.
Any help would be appreciated.
Originally posted by hwai View PostThanks for the advice but i was thinking even though it hang yet still possible to reboot is there a way to enter into recovery without connecting to pcOriginally posted by leolas View PostIn my both sticks mk808b and imito QX1 if I press the reset button while power on the stick (and the device is not conected to a pc in otg port) it enters in recovery mode after 30 second or less. That is the only key combination who works for me.
But I can't assure that this will work for all sticks.
leolas.
Code:su reboot recovery
Originally posted by webipsum View PostDo not know if this is the case, but in mine, from Android, I run the Terminal:
There are currently 4167 users online. 3 members and 4164 guests.
