CWM recovery for rk3066 devices.
Originally posted by memo View PostDears plz help me
i already follow the steps to install recovery and after update its keep open recovery i cant boot to my android interfaceREMEMBER, YOUR FEEDBACK IS VERY IMPORTANT TO US.My devices:
Originally posted by memo View Posthi its new
this is the specification
i remmber also build number
its like this exactlythe update.zip are not recogniced by the new recovery used in this stock roms so I suggest to install it using terminal emulator (the less invasive way) I made some scripts and instruction here:http://www.freaktab.com/showthread.p...ery-for-rk3188
I dont understand you well, now, in this moment after use the update.zip way to install cwm, your stick boots in the stock recovery and you cant boot in android, right?REMEMBER, YOUR FEEDBACK IS VERY IMPORTANT TO US.My devices:
Originally posted by leolas View PostIf you come from 4.2 stock roms, seems that use the update.zip way to install cwm rarely worksthe update.zip are not recogniced by the new recovery used in this stock roms so I suggest to install it using terminal emulator (the less invasive way) I made some scripts and instruction here:http://www.freaktab.com/showthread.p...ery-for-rk3188
hi yes its 4.2
i download the cmw and rename file to update.zip by using file explorer included in the stick then i move it to root directory then turn off and turn on again after booting to android interface i see popup message ask for update i click ok then device restart and boot in recovery mod i choose reboot system now but it open recovery mod again
so what can i do now exactly also can i use rooted room in my device ?
so what can i do now exactly also can i use rooted room in my device ?REMEMBER, YOUR FEEDBACK IS VERY IMPORTANT TO US.My devices:
Originally posted by memo View Postthis one sorry i dont have experience in thisok, seems that you have cwm installed, now lets make a backup of your system to an external sd. Seems that something is wrong in your misc.img or you loosed your boot.img or kernel.img. so lets see if you can backup all your system, pay attention to the error message that appears in the screen and tell me what is going. I will stay some hours online this afternoon, I am compiling kernels so sometimes I can last a bit to answer, but we will try to solve it.
Seems that the problem is on misc.img, but I want to be sureREMEMBER, YOUR FEEDBACK IS VERY IMPORTANT TO US.My devices:
Originally posted by leolas View PostDon worryok, seems that you have cwm installed, now lets make a backup of your system to an external sd. Seems that something is wrong in your misc.img or you loosed your boot.img or kernel.img. so lets see if you can backup all your system, pay attention to the error message that appears in the screen and tell me what is going. I will stay some hours online this afternoon, I am compiling kernels so sometimes I can last a bit to answer, but we will try to solve it.
anyway i CONNECT FLASH MEMORY TO OTG and try to take backup to external sd but i see error message cant mount backup path
Originally posted by memo View Postlook i dont care if i loose the current files so if u have any rooted room work with my device it will be better
A usb flash memory is not valid to make a backup, you need to insert a formmated in fat32 miscrosd in the stick. and if you got a backup, I will sent you a flashable zip to flash the misc.img so you can enter in android again. after we have a backup we will try to install a new custom romREMEMBER, YOUR FEEDBACK IS VERY IMPORTANT TO US.My devices:
Originally posted by leolas View PostI suggest finless 1.7 (4.1) or 2.1(4.2), but some new mk808b sticks comes with a different wifi chip (AP6210 instead rk903), so that is cause I suggest a backup before install any rom. so will have your system safe.
ok 2GB sdcard enough for backup ?
Re: CWM recovery for rk3066 devices.
Originally posted by memo View Postok 2GB sdcard enough for backup ?
leolas.REMEMBER, YOUR FEEDBACK IS VERY IMPORTANT TO US.My devices:
There are currently 4214 users online. 3 members and 4211 guests.
