I am doing the zip to fix your misc partition, wait a moment please.
CWM recovery for rk3066 devices.
Originally posted by memo View Post
I am doing the zip to fix your misc partition, wait a moment please.REMEMBER, YOUR FEEDBACK IS VERY IMPORTANT TO US.My devices:
ok, copy this file:http://www.freak-tab.de/leolas/fix.zip to a sdcard, after that in recovery, enter in:
mount and storage/format cache
after that enter in:
install zip from sdcard/install zip from an external sdcard
select fix.zip
wait until the zip is installed. After that it will boot in android when you select reboot in cwm menu
You can now install the 2.1 or 1.7 rom by finless from cwm recovery using the instructions in:http://www.freaktab.com/showthread.p...stallable-zips
Tell me if it works for you.REMEMBER, YOUR FEEDBACK IS VERY IMPORTANT TO US.My devices:
Originally posted by leolas View Postok, copy this file:http://www.freak-tab.de/leolas/fix.zip to a sdcard, after that in recovery, enter in:
select fix.zip
Originally posted by memo View Postafter install fix i reboot system from cmw menu but its also boot to recovery again .update.zip way to install cwm recovery usually fails in 4.2 roms.
For sure your boot or kernel are damaged too
Then I suggest you enter in mount and storage and format:
-data
-system
-boot
-kernel
-sdcard
Tell me if there is any errors.
After that follow the steps in http://www.freaktab.com/showthread.p...stallable-zips and downlooad finless 2.1 rom or another one, uncompress the rom and follow the instructions to flash the new rom.
Or you can flash the device in the traditional way and use the instructions provided by the rom author.
I suggest you if you flash a new rom using the pc and want to have cwm recovery use the second way(from terminal emulator) in:http://www.freaktab.com/showthread.p...ery-for-rk3188
It is for rk3188 devices, but it must work in rk31066 devices too (yours)
Originally posted by leolas View PostUrps, then not only misc.img is damagedupdate.zip way to install cwm recovery usually fails in 4.2 roms.
-data
-system
-boot
-kernel
-sdcard
i want one help if my brother bring his device how i can take full backup from my bother device and use it in my device to restore all factory ROM ?
thanks again
Re: CWM recovery for rk3066 devices.
Yes
leolas.REMEMBER, YOUR FEEDBACK IS VERY IMPORTANT TO US.My devices:
Is not dead, push the reset button while you connect the usb to otg port, Windows will ask you about install drivers.
Windows 7 is recommended.
Originally posted by leolas View PostIs not dead, push the reset button while you connect the usb to otg port, Windows will ask you about install drivers.
leolas.
which reset button u mean ?
when i connect the usb throw OTG i see 2 drive
i opened ROM_Flash_Tool_137
Originally posted by memo View Postits ok now
i watch youtube video and know hot to reset it
i tried flash MK808B Finless 2.1 ROM working fine but wifi and Bluetooth not working
can u explain how i can backup my second device to restore it on old one ?
Make a backup to external sd, then install cwm in your device and restore it, if not, first root the device using morobo and tspatky way, in geekvuying blog they explain how to do that, sorry but I am out of home and I will be completely out of battery soon. Tomorrow I will try to explain it better if you can't solve it.
There are currently 2246 users online. 0 members and 2246 guests.
