CWM recovery for rk3066 devices.
    Yes, Bob found a way shorting 2 pins on the nand and making the stick enter in mask mode, but Try first change wires, usb or even pc first if you can.
    leolas
    My devices:
    Gearbest.com)
      leolas
      I've tried to use that trick with the wires 8&9 and no luck. Once I managed to flash the IDB but never to install the ROM. insane! I'm loosing my mind.
        Re: CWM recovery for rk3066 devices.
        Have you tried using RK Batch Tool?
        The RK Android Tool, will abort the flash if detects a bad sector.
        Tapatalked
        if [ $up.post.type = $type.two.lazy.to_use_google ] || [ $up.post.type = $type.silly_question ];
        then mv $user.contact.up.post /.trash; set response($response.type = ignore);
        $user.up.post.ignore_in_future = true; fi;
          Tapatalked
          Great idea, try to install the stock to format the nand.
          leolas
          My devices:
          Gearbest.com)
            Tapatalked
            leolas
            will try that and will get back in a moment.
            Thanks.
            EDIT: no luck
            strange that sometimes goes to 20 something % and sometimes only 13%.
            It looks like it stops being in flash mode while flashing.
            If its a bad sector is there anyway to fix it?
            going crazyyyy
            screenshots:
              and whats the minimum sized image out there? Because on ROM Flash Tool.exe It went flashing to about 260 MB then it goes down. If I can find an shorter image maybe I can make it run something...
              maybe not. I don't know, but it's really making me go crazy.
                If you change the usb wire yet, maybe is the usb port the problem? Maybe a bad solder point?
                Maybe nand chip is bad?
                Sorry but no more ideas from my side
                leolas
                My devices:
                Gearbest.com)
                  leolas
                  Hi Leolas,
                  I have flashed everything except system file and I got it to boot:
                  But the problem now is that I have no way to use my mouse with it. (well at least its not working)
                  any way to choose something from this screen?
                    Hi Leolas,
                    Have you a usb Keyboard to connect to it?
                    leolas
                    My devices:
                    Gearbest.com)
                      leolas
                      no. I have used and wireless one.
                      Will test and post back. Thank you soo much for everything. I feel I am closer than ever to get this one back alive
                        Yes, you are near.
                        leolas
                        My devices:
                        Gearbest.com)
                          Yes, you are near.
                          leolas
                          I can't get to access my external sd card when booting CWM. Any way to work around this?
                            Ate your external sdcard formated in ntfs, it is not supported try with a external ascard formatted in fat32
                            leolas
                            My devices:
                            Gearbest.com)
                              leolas
                              And I just substitute the recovery.img inside the CX803_CWM.zip with the one on finlessROM?
                              (i am flashing everything except the system.img - because I always get an error flashing system.img.
                              EDIT: What I am trying to do is:
                              since I always get an error flashing any system.img or any big file. I can erase IDB and then flash everything else, then maybe I can flash with CWM a system file from external sdcard.
                                Yes you are right, this waqy can work.
                                Erase IBD and flash your bootloader, parameter and cwm-recovery only.
                                Dont mark boot.img noe kernel.img
                                After this in the restart you will enter in cwm recovery.
                                From recovery format system, data, cache, boot, kernel and sdcard (if you can, probably sdcard will fail but don't worry, because when system boots it will be formated from settings)
                                Use this zip http://www.freaktab.com/showthread.p...stallable-zips to add inside your boot.img system.img and kernel.img.
                                flash it using cwm.
                                after wipe data/factory reset.
                                Then reboot and we will see.
                                My devices:
                                Gearbest.com)
