CWM recovery for rk3066 devices.
Originally posted by vijayar View PostI also have 808 and I think there is some issue with existing CWM that has been posted since I too had reported earlier that mouse was unresponsive. Can you contact fun is possible and highlight this issue ? Thanks in advance
Don´t pm him so he usually will not answer pm.
Poisonwolf post in the xda thread, that is the correct way to feedback him. Now when he can he will answer PoisonWolf, and sometimes he ask for extra info about the problem. Try to explain your problem clear to him and append all details you can, maybe he ask you dmesg or another test.
Sorry but i cant help cause i don't have mk808 and i don't have this issue in my mk808b.REMEMBER, YOUR FEEDBACK IS VERY IMPORTANT TO US.My devices:
HI:leolas & bob
i have a question about my mk808,the device is flashed by bob's finless1.6 ROM and work well,then i install leolas's cwn-recovery(by update.zip method) and work well too.
now i want flash a new kernel,but in any case the devie can't enter flash mode,my computer(xp os)always prompt "No Found RKAndroid rock usb",i try many times but failure.
why?,thanks.
best regards!
Re: CWM recovery for rk3066 devices.
why?,thanks.
best regards!
Now lets try to help with your problem:
Unplugg everything, push with a clip the reset button and while is pressed plug the usb wire to the stick at the OTG port.
Now your pc must recognize your stick in loader mode, so you can flash all you want.REMEMBER, YOUR FEEDBACK IS VERY IMPORTANT TO US.My devices:
Originally posted by leolas View PostFirst, it's not my cwm, it's fun_ the developer who brings this tool to us.
Originally posted by leolas View PostIn the first post i have links to the threads where fun make changues and receive feedback.
Originally posted by PoisonWolf View PostLeolas, out of curiosity, is there another way to boot into recovery without using the reboot app? Maybe something is happening as the device is rebooting that's causing the mouse/keyboards to not be detected.REMEMBER, YOUR FEEDBACK IS VERY IMPORTANT TO US.My devices:
Originally posted by liuchen2 View PostI just according to this method,try another same type mk808 and replacement of using other computer,but can't enter flash mode,the TV show already enter CWM interface.
Now in the pc, open rkflashtool.
Plug a USB wire to the pc.
Now with a clip push the reset botton in the stick(it's in a hole at the opposite corner that the blue led) and maintain it pushed.
While reset button is pushed plug the USB wire to the OTG port.
The pc must sound. New hardware detected. Then you can release the reset button.
In rkflashtool you must see "rkdevice found in loader mode".
Flash the new kernel.
Hope this helps.
PD: The USB port at pc must be usb 2.0 and direct in the pc mainboard.Last edited by leolas; 22 February 2013, 08:30.REMEMBER, YOUR FEEDBACK IS VERY IMPORTANT TO US.My devices:
Originally posted by leolas View PostPls, if you can, do that I say, unplugg everything, everything is all wires attached to your stick. HDMI wire, power usb wire, all
Hope this helps.
sorry for my english
Originally posted by miron2 View PostLeolas, too, so I have, after uploading the wrong firmware, in my MK808B (MT5931) flash button does not work, so I ask if there are other possibilities recovery, for example, CWM restore recovery, but you need a CWM backup maybe.
sorry for my englishI am working to make zips flashable by cwm. But not ready yet.
Do you try reboot to bootloader in the reboot apk in finless Rom?
Or type in terminal emulator:
su
reboot bootloader
Then you must enter in loader mode and you can flash using rkflashtoolREMEMBER, YOUR FEEDBACK IS VERY IMPORTANT TO US.My devices:
Originally posted by herby68 View Posthi friends
how to get cwm with a rooted MK808b running with finlessbob´s rom?
thx
HerbyREMEMBER, YOUR FEEDBACK IS VERY IMPORTANT TO US.My devices:
There are currently 3016 users online. 0 members and 3016 guests.
