CWM recovery for rk3066 devices.
Originally posted by leolas View Post
Re: CWM recovery for rk3066 devices.
Originally posted by Finless View PostTo make a ROM flashable by CWM, you have to learn to write edify scripts. Not hard but also not easy to a new person!
BobREMEMBER, YOUR FEEDBACK IS VERY IMPORTANT TO US.My devices:
Originally posted by Craxx View PostHy leolas
You compile kernels :-D
Perhaps you can share a good one ;-)
best regards
Craxx :-)
Send from my Nexus 4 with Tapatalk 2 :-D
Actually I have got boot and system mounted in linux so I can see what is inside. I compiled useless but instructive kernels. Maybe in a couple of years I can make goods roms jajajajajaREMEMBER, YOUR FEEDBACK IS VERY IMPORTANT TO US.My devices:
I am a great fan of the work by fun_
Came across his thread in xda while messing around with the generic Proscan PLT7035-B (RK2906 chip).
His CWM along with Orange Backup (I am quite lazy and prefer the easiest short cuts to backup stuff) is what I have on the MK802 III currently.
Hi Leolas,
Thanks for this posting, very helpful & good to find everything in one place/posting. My problems,
My CWM screen on TV is not fitting properly ; CWM main menu view is cut on top & below like an oversized image. Should be something to do with resolution how does one change it to see it completely ?
Androtab has mentioned mouse controls in "how to control" section, however my mouse (which works without issues in android) did not work with the CWM. I don't have any other mentioned devices to test. Due to this I was unable to test CWM.
About mouse, you must hold the mouse and move it to down to get like a cursor movement down. I don't know if you understand my explication.REMEMBER, YOUR FEEDBACK IS VERY IMPORTANT TO US.My devices:
Originally posted by PoisonWolf View PostDoes anybody have version 11/2 from the website? 13/2 isn't working for me and I cant get my keyboard or mouse to work.REMEMBER, YOUR FEEDBACK IS VERY IMPORTANT TO US.My devices:
Originally posted by leolas View PostCan you try it without any hub? In the OTG port? pls, your input device?
I've tried it with a wired keyboard in the USB port, in the OTG port. I've also tried a Microsoft Explorer Mouse and a Logitech M705 (a trackball) in the USB and the OTG port and it still doesn't work.
I'm completely stumped as to why this is happening because these devices work normally when Android boots up.
I've also tried reflashing the recovery.img twice using the flashing tool and still the mouse input doesn't work.
What version of the CWM file are you using leolas? Feb 11 2013 or Feb 13 2013?
I am using the last one, buy I will see if I have an older version downloaded.
This cwm had problems with some hubs, but I thought that fun solves them, I will try to search for an older cwm recovery zip, and I will tell youREMEMBER, YOUR FEEDBACK IS VERY IMPORTANT TO US.My devices:
Originally posted by leolas View PostI am using the last one, buy I will see if I have an older version downloaded.
Does it matter that I'm using 2dark4u's Kernel version 1.4 720p? I'm not sure if a kernel needs to be able to "support" CWM.
PD: I saw now that you have a mk808 without the "b", i have only copies of mk808b cwm.zipLast edited by leolas; 21 February 2013, 09:14.REMEMBER, YOUR FEEDBACK IS VERY IMPORTANT TO US.My devices:
There are currently 2042 users online. 1 members and 2041 guests.
