Kimdecent B13 / MK812 with external Wifi Antena - Finless BETA ROM 1.7
    Kimdecent B13:
    Hi Bob/Finless,
    sorry to bother you too with that Kimdecent B13 Stick (The new MK812 looks the same).
    Here is the Stock Firmware for that device:
    Maybe you could check it out and port the Finless ROM to that Device. It should be 95% the same since only WIFI/Blutooth seems to be different compared to the Kimdecent B12/Measy U2C. Maybe you could figure out whats different (So it might be enough to replace the wifi/blutooth part).
    Please help us Kimdecent B13 Users out. Thank you and keep up your awesome work....you rock
    I second the request for B13 Finless
      No worries.... I will work on it this week. I will try to get it done before I leave on vacation this weekend.
        No need to rush. I'm glad that your working on it. Thanks
        PS.:
        Will the 1080p Bootimage work too ? If i understood correctly that has nothing to do with the firmware itself ?!?
          HOw much NAND memory does this have?
          e.g. in setting>storage please tell me everything it says in there.
            Follows.
            A picture is worth a thousand words.
Name:	2013-04-05 18.39.49.jpg
ID:	429974Click image for larger version
Name:	2013-04-05 18.39.25.jpg
ID:	429975Click image for larger version
Name:	2013-04-05 18.39.00.jpg
            Marcos Nascimento
              OK got it.....
              I will have a beta ROM for you today!
              Stay tuned.
                You are amazing, thanks.
                Do you know if this Custom ROM comes with a 3G Support? My 3G Modem is a ZTE Model MF645.
                Thank in advance,
                Marcos Nascimento
                  Great news Finless,
                  thanks a lot for your work.
                  And thanks mpnascimento for helping out. My B13 looks just the same:
ID:	429977Click image for larger version
ID:	429978Click image for larger version
                  I wonder though how the MK812 Build looks...its supposed to have the same hardware (like 100% same) but there are rumors that they have a 4.2.1 Firmware for that device too.
                  Maybe i will find it and upload it here...it might be a better base for future builds.
                    Which port is the OTG port? the mini or the full sized one?
                    I have a B13.
                    I have tried to connect via the mini.
                    I have checked the box "Connect to PC" and then have searched for new hardware. Nothing.
                    I have also tried to connect via the full sized USB port to USB via a file transfer cable "Go! Bridge"
                    Also no luck.
                    I'm using Windows 7.
                    Any suggestions.
                      OK here is the BETA TEST ROM.
                      I cannot test wifi/BT myself since I do not have one of these so this is why it is a BETA test.
                      Please read the readme.txt for instructions and whats in the ROM.
                      http://cloud.freak-tab.de/public.php...7363409e4f3f37
                      Sorry of the download is slow. I am using a new place we are testing.
                        FYI - The download speed was fine for me ~4 mins.
                        Problem:
                        Step 3: "No found RKAndroid Rock usb"
                        - USB debugging is OFF
                        - in Device - Storage - the settings (3 dots) I only have "USB computer connection"
                        - If I hit this: I have 3 check boxes
                        1) "Media Device (MTP)"
                        2) "Camera (PTP)"
                        3) "Mass Storage"
                        Option 3 is the only one checked and it appears as if I cannot uncheck it.
                        Additional Question: What should my USB option be? "Connect to PC" checked or unchecked?
                        (I have tried both and it doesn't affect anything)
                        My build number is:
                        B13_RK3066_Public_V411_130301
                          Ok, a few resets [unplugs] and it all seems to be working
                          Kind'a odd that resetting the unit seems to set the settings, but it did.
                          The only real thing I had to quickly change was the display resolution.
                          Cool boot image,
                          Thanks Bob!
                            Unfortunately, I don't have the same result to install the drivers.
                            I think the cause is the Windows 8. I'll try install the drivers in a PC with Windows 7.
                            Thanks,
                            Marcos Nascimento
                              I supply Win 8 drivers in the X64 folder in /drivers.
                              Also as I understand it you must go into admin and turn off driver signing. The drivers are NOT MS signed.
                              Many have got win 8 drivers working.
