either delete the module that is installed , or enable it
Kimdecent B13 / MK812 with external Wifi Antena - Finless BETA ROM 1.7
So i just bought the mk812 from miniadroidpc a couple of months, and i only used the roms that the miniandroidpc site gave me. The last one i installed works well but i think it got too heated and i started seeing some graphic glitches. I've not been using it lately but im going back to it. What's the best rom for this?also do i need to use any other software differently?
Also why this is called b13?
i think it is called b13 and it is a no brand name , everyone calls it on their own
for me the newest and best rom is from neomode , android 4.2.2
is there a newer rom ?
also keep in mind there are 2 different B13 (B13 and B13s)
adamoz ask your seller maybe he can provide something
it is very hard to find these chinesse roms
Originally posted by Maxrunner View PostHow do i know if mine is B13 or B13s?
i think the newer b13 are b13s
the 0730 rom is for the b13s i think
i have tried it and it worked but went to 0518 becouse of the root
here you can find the 3 firmwares that i am aware of , just scroll down
http://extrabuy.wordpress.com/2013/09/17/pmd-itv3066g-dual-core-rk3066-android-mini-tv-stick-review/
here are all the firmwares for b13 and b13s
http://pan.baidu.com/share/home?uk=3693222424#category/type=0
i have not tried those that say b13s from august
Originally posted by mite_jan View Postif you have the stock firmware it should have the b13s in the description in about page
Originally posted by Maxrunner View PostMine is the one with the antenna and av out. It says B13 but on the last parameter it says B13s something. I just turned it on , but it seems to get stuck constantly....
mine was restarting all the time and it took me long enough to realise that the microusb cable that was powering the stick was bad
Originally posted by Maxrunner View PostIm using the usb from the tv to power the device and not the ac adapter...
the stick needs to get 5v 2A power
i dont think that the tv can get him that
i know that it boot (tried it myself) but i will never do that
anyway i think that the b13s firmwares will work too (becouse i have tried 0730 which said b13s) this one is the latest 08/28/2013
http://pan.baidu.com/share/link?uk=3693222424&shareid=1620986026
if anyone tries it share your experience
Here's my data: E=mite_jan;116427]why the hell are you doing that
if anyone tries it share your experience[/QUOTE]
Heres my data:
Model: B13
Build:B13s_RK3066_public_V422_130730
Is there a better rom? What about xbmc hd support?
Originally posted by Maxrunner View PostHere's my data: E=mite_jan;116427]why the hell are you doing that
Model: B13
Is there a better rom? What about xbmc hd support?[/QUOTE]
have you tried finless rom in this thread or the one from neomode ? did they worked for you ?
you can also try the one i included in this thread
Originally posted by mite_jan View PostHeres my data:
Model: B13
you can also try the one i included in this thread[/QUOTE]
Not yet, do i install these the same way i installed the official ones?
Originally posted by Maxrunner View Posthave you tried finless rom in this thread or the one from neomode ? did they worked for you ?
Not yet, do i install these the same way i installed the official ones?[/QUOTE]
no custom firmwares need to be installed with rkandroid tool (rk develop) that should be provided in the download zip
There are currently 2297 users online. 1 members and 2296 guests.
