Kimdecent B13 / MK812 with external Wifi Antena - Finless BETA ROM 1.7
anyone watching 720p,1080p movies through XBMC without stuttering ?
if yes share your setup
p.s i have found 2 firmwares from the russian friends which i have no idea which android is on them
the one should be rooted and the other should have 4.2 (not sure if it is the same firmware as for the mk812 few posts before)
http://android-console.ru/index.php?option=com_content&view=article&id=1230& Itemid=612
and
https://disk.yandex.com/public/?hash=xDyRhjAMgFisBHGNz20F4zNqJPHYmC6bdFjhnJzHQdk% 3D&locale=ru
Use XBMC libstagefright version with an advancedsettings.xml
Originally posted by mite_jan View Postanyone watching 720p,1080p movies through XBMC without stuttering ?
and
I use XBMC with hw acceeration for watching 720p/1080p videos everyday. No stuttering and almost perfect. All you need is a libstagefright build of xbmc and also need to create an advancedsettings.xml.
Originally posted by jeevas.v View PostI use XBMC with hw acceeration for watching 720p/1080p videos everyday. No stuttering and almost perfect. All you need is a libstagefright build of xbmc and also need to create an advancedsettings.xml.
which firmware do you have installed ?
the firmware that came with my stick probably doesnt have the libstagefright patch becouse i was not able to watch smooth HD videos
and also with what build do you have success
ok i finally get my hands on this device
i have immediatelly put android 4.2.2 and yes AV output works great and a huge antutu score bellow 10 000k , cant remember exactly but it was 9700-9800 probably becouse i am using lower resolution with the AV output
xbmc works great with HD videos too (thanks god)
my only issue is that i cannot root it
geekbuying says that the instructions are as these
but my device cannot get recognised with the usb cable (tried 2 cables)
standard to standard usb , maybe i am using the wrong cable
any other way to root the stick ?
like have a prerooted firmware and than install it
can i get some help with rooting the device
Originally posted by neomode View PostOk Guys, i have the new 4.2 Rom for this thing with Support for AV Out.
In the next Day will make a Crom.
Neomode
also can you please make one flashable img file that can be flashed through RKbatch tool not RKAndroid tool (the second one freaks me out , and i have dumped one stick with it)
oh yeah i noticed when i uninstall app after saying uninstall finished it pops quickly cannot read /data/xposed/modules.whitelist
maybe this happens becouse there is the netflix module but it is not active ?
Originally posted by adamoz View PostHi the Wifi on these B13's is it any good? is it better than MX1? I really want a device with atleast a bit better wifi than the MX1..
Does the camera work in this Finless ROM? And wow thanks Finless you are really improving the whole Android stick industry.
finless rom is based on the stock rom for the b13 with android 4.1 and camera works ofcourse
there is 4.2 for this device but not finless rom
Hello mite_jan,
Did you managed to solve the "cannot read /data/xposed/modules.whitelist" problem?
Thank you
There are currently 2100 users online. 2 members and 2098 guests.
