Kimdecent B13 / MK812 with external Wifi Antena - Finless BETA ROM 1.7
Originally posted by DiZet View PostHi neomode. Are you still planning to release a new rom or you have abandoned the idea?
Or Finles/Bob making a Finless 2.0 or something...but having lost his father (I know that feeling, mine died a couple weeks ago...cancer) and lots of the new quad devices around i doubt it...so sad
how have you rooted the stick guys ?
mine came with stock 4.1.1 non-rooted and i am using it on an old TV via the AV output
i have immediatelly installed the XBMC libstagefright build and noticed that hardware decoding doesnt work with HD(720p and 1080p)
what do i need to update so xbmc should play at least play 720p good
do i need to update the libstagefright lib and how can i do that
i have found CWM flashable zip that includes couple of files
if i replace them from here will it be a success story ?
http://www.freaktab.com/showthread.php?4021-cwm-recovery-zip-for-the-new-libstagefright-so
also for root how do i need to power the device , DC port in the power outlet , standard usb in the PC (with standard usb male to male cable ?
click meLast edited by mite_jan; 15 July 2013, 02:41.
click me
Finless rom comes fully rooted, so just install it on your stick. Link is on the thirst page, post 11 by Finless. Instructions are in README FIRST.TXT.
Originally posted by DiZet View PostFor XBMC look here http://www.freaktab.com/showthread.p...d-what-doesn-t
i will try to replace those files provided by leolas for xbmc HW decoding
hopefully i can first root it
any usb hub support with Finless 1.7 beta?
Just received a new shipment of B13-s. Switched them on and all have 4.2.2 on them
Checked the A/V out and it is working. Antutu score was 7493. In "sound output devices" there is 3 options including 5.1 multichannel. Do not know if it is actually working since I have nothing to test it on.
So the official rom must be out. Do not know where to download it from though. Will ask the supplier maybe he knows.
Originally posted by DiZet View PostJust received a new shipment of B13-s. Switched them on and all have 4.2.2 on them
talking about this firmware https://www.dropbox.com/sh/sqd2f2l8zgis8th/xoF_aE1Zpj/MK812-Firmware-V4-2-2-Ext-Antenna.zip
havent tested it myself if AV works
can you make a screenshot from the about page ?
is it the same as this ?
No. It is different built number. And Finless rom is not compatible anymore. They must have changed something with WIFI
After flashing Finless rom or the one mite_jan has posted above there is no WiFi anymore. It just does not work.
So no auto hide status bar option anymoreAnyone knows any alternative way of getting it?
Originally posted by DiZet View PostNo. It is different built number. And Finless rom is not compatible anymore. They must have changed something with WIFI
maybe they just changed the wifi adapter
Originally posted by neomode View PostOk to help you gave me your dmesg output.
Then I can see what they change.
NeomodeAttached Files
There are currently 1611 users online. 3 members and 1608 guests.
