Kimdecent B13 / MK812 with external Wifi Antena - Finless BETA ROM 1.7
Originally posted by Maxrunner View PostDo you mind post the latest version link? I assume it includes everything?
regards,
http://www.freaktab.com/showthread.php?6517-Kimdecent-B13-MK812-Jesurun-NX003
but if i was installing firmware from beginning i would try this one first from September (just check if wifi bluetooth works fine)
http://pan.baidu.com/share/link?uk=3693222424&shareid=1620986026
both firmwares are not installed with the same tool
Originally posted by mite_jan View Posti am using this one which is firmware from May , it is pretty much like stock except it is prerooted
Gotcha. So what's the procedure for these roms? i only used the tool given by the seller.
Originally posted by Maxrunner View PostGotcha. So what's the procedure for these roms? i only used the tool given by the seller.
for the first link you need to use the tool that is included in the zip
there should be a readme file
you can handle it
There are currently 2063 users online. 2 members and 2061 guests.
