MK808-B (original) JB 4.2.2 Official - Finless ROM 2.1
    Originally posted by womackbug View Post
    Trying to find the original mk808b. I order a couple off Amazon but now the are shipping out clone. I was wondering who makes the original and where can I buy one. Thanks
    I bought mine half a year ago from them: http://www.aliexpress.com/store/prod...031689722.html
    It looks exacly like on photos. I believe this is genuine one.
      The original is not manufactured anymore. You have to be very lucky to find a seller that has it still in stock.
        I've checked and I confirm - it's rk903 device.
          Is there a way to flash Finless ROM 2.1 using Mac OSX (10.6.8.) ?
          I'm stuck with only a Mac for a couple of weeks, and need to flash Finless 2.1. Rom to my mk808b
          So how can i do it on Mac OSX ?
            Wifi Not Working Using MK808b ROM
            I flashed my Android Dongle (http://web.natec-europe.com/Z17900_46149.pdf) with the MK808-B ROM.
            Basically I've read that this is not for clone devices - still I wanted to give it a try.
            Well - it worked pretty fine and my device is able to boot.
            BUT
            Trying to turn on WiFi the device is frozen. Even after starting the device again.
            Any chance for support/hints?
            (Opening my device I see that there are "Nanya"/"SK hynix" chips inside)
              Your device is not even a MK808(B), i don't know why you thought a mk808B ROM will work on this. From the outside it looks like a cx-803, maybe you should search for a ROM in the cx subforum: http://www.freaktab.com/forumdisplay...-CX-TV-Players
                freaktab webmaster is god!! as you see "carterkn" probably banned
                and very effective to delete flooded shit on our great and respectable forum.
                thx and keep the good work freaktab
                  Hi , Thank you for your fantastic rom! I just have one doubt: I need to be able to rotate the screen when pressing a button in an app. I have implemented the solution, it works in a tablet , but it doesn't using this finless rom. I have tried modifying the build prop , but then the solution is not dynamic... Is there any change I can do to modify the rom , or something that allows the android tv to be able to rotate dynamically? Thanks!
                    There is an exposed module called "App Settings" where you can set a forced rotation for individual apps. I have not tried it on the mk808b though.
                      Thank your for your answer . I am going to try it right now , but I have already tried all the rotation screen aps without luck , so maybe this will be the same , but you never know! I will let you know when i figure out how to install this app , thanks again!
                        Thanks for your help , but app setting is not working at all , any other ideas?? Thank you!
                          not work error download idb fail
                          I'm delete flash nada and try install this finals rom any time error download idb fail I try the connect tv Its not work tv show nosignal It hasn't nada chip how fix please help me look thise picture
                            Originally posted by nipun View Post
                            I'm delete flash nada and try install this finals rom an time error download idb fail I try the connect tv Its not work tv show nosignal It hasn't nada chip how fix please help me look thise picture
                            Hi friend, i coukd help you with that.... as bob said in his first post : this rom is for mk808b original only. not for clone like sunvel model..
                            original have rk901 wifi chip and i see you have a rtl8723bs wifi chip so you got a clone.
                            You got the new mk808b v5, here's a rooted firmware
                            https://mega.co.nz/#!0FM1RSbD!BSie8fdcARTqQHrAy7xKzIPYd3BX01as5id9eiS F3-0
                            thx mike808 for the rooted rom
                            Use the RK Batch tool to flash this firmware on the new v5 MK808B. Load the firmware files and press restore.
                            i hope that would help you to get to roll the beast again
                            a link about your device there :
                            Have Nice Day with your new device
                              This clone has the same WIFI chip but is not a V5 (totally different PCB).
                              This Firmware is for you:
                              百度网盘为您提供文件的网络备份、同步和分享服务。空间大、速度快、安全稳固,支持教育网加速,支持手机端。注册使用百度网盘即可享受免费存储空间
                              You may also have messed up your NAND by flashing a wrong bootloader, so if flashing keeps failing with the right firmware, you have to short pin 8&9 on your NAND chip as described to this guide: http://www.freaktab.com/showthread.p...D-on-the-MK808
                                Hi there,
                                are there modules for wifi sticks in this rom available ?
                                I am looking for a module for my old RTL8188SU:
                                http://www.realtek.com.tw/DOWNLOADS/dow ... loads=true
