MK808-B (original) JB 4.2.2 Official - Finless ROM 2.1
flash to external SD card?
Hi Bob. Thanks for your good work. I have a question for you. I ruined my nand flash a few months ago. I'm still able to flash kernels and other small files but nothing bigger than I'd say 50 to 60 mob
Is their a.way to flash your rom or any other rom to an external SD card?
Thanks.
PS. Maybe I should start a new thread about this.
Originally posted by sti.que.c.pas.facile View PostHi Bob. Thanks for your good work. I have a question for you. I ruined my nand flash a few months ago. I'm still able to flash kernels and other small files but nothing bigger than I'd say 50 to 60 mob
Thanks.
Your device then boots to CWM recovery and then you can flash a CWM rom from an SDCard.
Or does this also fail?
Originally posted by mo123 View PostHave to tried to flash only boot, misc, CWM recovery & kenel after IDB erase.
But will this flash the rom to the SD card or the internal nand?
Gonna try this and report result...
Edit: seems to work. Gonna play with it for a few hours and see if everything works. I should have waited before I bought an mk908ii .... One TV , 2 sticks.
Edit2 : OK here's the thing. system works ok but Nand flash isn't mounted. Also they're a few video file that glitches. I formated the internal flash and it seems OK now but still video glitches with some files that play fine on my laptop. I used 720p kernel and boot . video files are mkv. Any ideas?Last edited by sti.que.c.pas.facile; 26 December 2013, 18:50.
Originally posted by phinc View PostTest it with some other players. (MX Player, VLC, ...)
Originally posted by phinc View PostSeems like your internal sd got corrupted. Go to settings -> storage and format your internal sd.
Sent from my GT-I9100 using Tapatalk
Thanks again.
Bluetooth Issue
I upgraded from an older Finless Rom (I'm not sure which) to 2.1 and now when I reboot my stick, my bluetooth keyboard/trackpad doesn't reconnect. Every time I reboot I have to plug in a USB mouse and delete it from the bluetooth connections, and pair it to the stick again. Do you have any suggestions?
Is there a way to flash finkess 2.1 rom on the MK808 withe an app and root access)
Hello !
Is there a way to flash finkess 2.1 rom on the MK808 with an app / apk and root access) ?
Like "Mobile Odin pro" or rom manager ?
I cannot manage to make rockusb flasher work on pc (detect, but only as mtp
see : http://www.freaktab.com/showthread.p...ht=#post128540 )
Thanks !
There are currently 2553 users online. 2 members and 2551 guests.
