openelec for MXIII-G (amlogic S812) ?
Originally posted by al8782 View PostI've used different builds for the M8 box from both Codesnake and Kerber. I figure I ask here because you guys seem to really understand some of these builds. But my question is. Why does Codesnakes builds have only 2 cores working and Kerbers has all 2 cores a workin?
Originally posted by wilro_6276 View PostThis is probably related to the scheduler selected by default in the build - The "ondemand" scheduler keeps all 4 CPU cores running, whereas the "hotplug" scheduler powers the cores up/down depending on system load - There is a problem in the newer kernels whereby it doesn't seem to ever power up more than 2 cores, so I suspect the one that shows all 4 cores in use is using the former scheduler to get around this problem. (It appears that the android roms use hotplug, but are running on an older kernel that doesn't exhibit these problems)
Originally posted by envagyok View Post
With 6.0.0.2.b and kszaq 5.95.5.2a after flash to nand isnt boot, just blank screen.
I make photo from pcb front and back, i post it.
With amlinux.ru 6.0.0 MX3G version working, but bad deinterlacing quality has, and sometimes video playing with jerky picture.
Nextxeon MXIII-G V2.0 S812/1G/8G/AP6181 (M82G_V1.0_20150324
NAND : EMMC 4.51 : foresee NCEFES78-08
Gigabit lan : Pulse H5007NL
WIFI AP6181
thanks
Originally posted by loce View PostHi,
i tried install some versions to the box but i can just received the android system recovery,but the opnelec can1T install.
My ROM now:Tronsmart MXIII Plus_106L1_151029
I did the boot with the tooth "toothpick trick".
Any idea?
I am interested the same question.
Can openelec installed on Tronsmart MXIII Plus. (Amlogic S812 Quad Core, 1GB/8GB).
Thanks.
Any idea?
Thanks.
[QUOTE=loce;Hi,
Any idea?
Thanks[/QUOTE]
Thanks.
There are currently 2769 users online. 0 members and 2769 guests.
