JustMe ROMs v1.9 s802 ap6330 01/10/2015 (M8 / T8)
Originally posted by tdcompuservices View Post
We can get into TWRP main menu, but when select External SD then nothing show below (Subdirectory), We wait almost three minutes still no luck
there is a chance, can you share recovery.img up here (the one work for you)....
Grab TWRP 2.8.7.0 K200 (10.816k) and use this as your recovery.img. This guy worked for me.
The TWRP subdirectory on the SD card has to look like this:
Go into Restore and 1.9c will be there.Nvidia Shield (2017 & 2019), A95x Max, WD EX2 NAS
Originally posted by cjeman View Post
td.. Go here:
http://freaktab.com/forum/tv-player-...devices/page1=
This is the link where is my image downloaded and rename to recovery.img
Still I didnt see any subdirectory after selected EXTERNAL SD (step 8 and 9) on the link you providedLast edited by tdcompuservices; 14 November 2015, 22:47.
root of sd
TWRP
recovery.img
when clicked on TWRP folder you should see BACKUPs folder and file called .twrps
when backups folder is clicked you will see K200 folder
when K200 folder is clicked you will see folder with dates etc KOT49H etc etc
inside that folder you will see all the backed up files
does that sound like your structure?
Bugs are Sons of Glitches!
JustMe
for you it should be first linkBugs are Sons of Glitches!
JustMe
download the one from freaktab and you should be rightBugs are Sons of Glitches!
JustMe
JustMe
YES, also download from here
http://freaktab.com/forum/tv-player-...mlogic-devices
This is what you (JM) said on email to me with the link of 1.9...
"I used this recovery image TWRP 2.8.7.0 K200 - Beelink S82/S82B/S82H+Ap6210/Ap6330 and MXIII(1G&2G DDR)+AP6181/AP6210/AP6330 and Tronsmart S89/S89H (114k4)
and just renamed it to recovery.img and placed the file onto a SDCARD and did a toothpick recovery mode and selected the destination of the twrp backup and pressed restore."
Now base on this wording, I just found out
If you last click on RESTORE that mean you are using TWRP Manager. apps
However still doesn't work, event I saw all files in External SDLast edited by tdcompuservices; 14 November 2015, 23:22.
@JM
- Beelink S82/S82B/S82H+Ap6210/Ap6330 and MXIII(1G&2G DDR)+AP6181/AP6210/AP6330 and Tronsmart S89/S89H (114k4) - Confirmed
TWRP 2.8.7.0 K200
That is where I downloaded and rename to recovery.img
Is that correct link?
Originally posted by cjeman View PostYes... This link will get you the file that you need to rename. This along with the unpacked 1.9c on your SD card is all that you need. The toothpick reboot will kick in TWRP and then do a Restore using 1.9c.
@TD - do you have teamviwer if you do please email me your credentialswill be here for another 20minutes off to see the fight UFC rhonda roussey soon
also might have good news won't know till tomorrow if I have fix the wake up bug withoput using wake me scottie appLast edited by JustMe; 15 November 2015, 04:37.Bugs are Sons of Glitches!
JustMe
Originally posted by JustMe View Post@TD - do you have teamviwer if you do please email me your credentialswill be here for another 20minutes off to see the fight UFC rhonda roussey soon
Go ahead watch UFC, We watching Basketball between BKN & GS....we will jump back to find out TWRP after the game...Have fun
There are currently 1505 users online. 3 members and 1502 guests.
