Inphic SPOT i5 S805 media Player
Gathered version Lebreelec for i5 (to run from external SD card, standard stitching remains intact). If you are wishing to try, the image recording can be taken here. To use, you need to activate your universal multiboot (the image has all the files you need, just use the update mode of the standard firmware). After activating multi-boot , you need to uninstall the script aml_autoscript from SD card.
Hello Folks.
I'm looking for the firmware for the inphic i5. All the links to the original inphic.com site are dead here. Can someone point me in the right direction for it. I've been looking for the past few days, had no luck so far.
The inphic.cn website starts off with the i7, no mention of the i5 there..... Any suggestions ?
Thanks.
Hi here is one link:- https://drive.google.com/open?id=0B7...Go4WUVNb2x5S3M .
This is the USB install.
The sd card one is still uploading.
Cheers
kevin
Hi here is the sd card install link:- https://drive.google.com/open?id=0B7...jNFZU16YU5FS0k
Cheers
Kevin
Originally posted by kevin1341 View PostHi here is the sd card install link:- https://www.dropbox.com/s/mf93sme2s1...5_OTA.zip?dl=0
Cheers
Kevin
An old friend asked me to try fix this i5, Iv'e fixed many bricked devices over the years so I took on this challenge. I'll read back over this thread to familiarize myself with the process. The unit starts with the 'inphic®' word then gets stuck on the 'loading' screen (with the moving red dots underneath) so I can't access any menus internally. I'm just hoping I don't have a bad logic board here.
l'lI drop back and let you know the results. I'll put the files on Google Drive also and get a fresh tutorial together for future use. I may need to pop back before that to ask a question or two, ;-)
Again, thanks for your help Kevin, I really appreciate it.
There are currently 3571 users online. 0 members and 3571 guests.
