Inphic SPOT i5 S805 media Player
Hi Inphic JIm,
Could you please re post this attachment:- bridge-pins-burning_Inphic.jpg.
The attachment is not there.
I still can not get past the 4% error in usb burning tool.
Cheers
Kevin
Cheers
Kevin
Cheers
Kevin
Originally posted by INPHIC - Jim View Post
We have a testing OTA package that you could test. This is the link > http://goo.gl/ESdCmV
Once your system is updated, at your first test attempt, do not change CPU's frequency is given by default.
Let me know about any result.) Apart from minor instabilities, that could probably be solved with a thermal pad connecting the processor and the big aluminium slab above it, I have a few more nitpicks:
- the Vidon XBMC is crashing every time I try to play anything from my tvheadend server (the official Kodi 15.2 from Play Store is working perfectly),
- with external USB sound card connected, I get only two levels of volume: on and off (the same card works as expected connected to a normal PC or Orange Pi, also running Android),
- with sound routed through the USB card I get some faint cracking in the speakers every now and then (not present on an Orange PI). Setting the frequency of the Spot to 700 MHz makes the cracks
much less frequent
I also have the same problems with the remote as all the guys with black case and white remote combination. Can I do something about it other than removing the top cover entirely?
Keep up the good work!
Peaquino
Originally posted by nitrogen_widget View PostKodi from play store still locks up the device when I try to do anything it seems.
I then have to unplug it.
is there a fix that I missed in this thread?
http://freaktab.com/forum/tv-player-...7-simple-steps
Is the box compatible with all 2.4 remotes, like these?
http://www.****.com/itm/Quality-Wire...oAAOSwgQ9VudAT
Hi INPHIC-Jim,
As post #205 Huge improvement
First new firmware load since delivery in Dec '15 - I used a usb stick and the inbuilt update app.
Spot i5 is now watchable and only occasionally freezes (probably when source error rate is bad), not every time it's used.
Earlier I had fitted a stick-on heat-sink to s805 as posts here were suggesting overheating, -no effect.
Thanks for your efforts.
Peaquino
[email protected]
There are currently 2439 users online. 0 members and 2439 guests.
