I found a setting with screensaver, and noted (I guess by default??) it had a tick in the 4 minute box. I unticked it, and now the box stays on all the time.
Inphic SPOT i5 S805 media Player
Originally posted by viewer View PostI have found a way to keep my box from not shutting down.
If you press the power button while in the screensaver, the MCU will understand that you want power-off, so the system never will back.
We have some work to do around this, but it is good to hear you fixed the problem.
Originally posted by suttyom View PostI have a little problem. When i starting the Kodi application, the tv box is crashing, freezing. It needs a restart. You have any solution for this? First of all, I bought the box for using the Kodi. Thank you!
Trimis de pe al meu GT-I9301I folosind Tapatalk
Originally posted by manu-de View Post
Hi suttyom I have same problem, I test a lot of kodi versions and all firmwares, i ask to inphic here and they not answer any about this problem.
then test latest Kodi here - http://mirrors.kodi.tv/nightlies/and...rmeabi-v7a.apk
Originally posted by suttyom View PostYes, i was interested. I upgraded the software, but the problems is not resolved.
Please, follow these 4 steps:
1. From Google Play, look for: terminal emulator
Install the app, do not need to open for now.
2. From your SPOT i5, open the internet navigator (browser) and type this URL:
Code:http://goo.gl/htH6VV
3. Now open the terminal emulator downloaded on step 1
It will show you "$"
Now type:
Code:su cp /storage/sdcard0/Download/20151223_freez1.zip /cache reboot recovery
4. After reboot you will see the recovery menu
Use the remote and choose: "apply update from cache"
Now select: 20151223_freez1.zip
After finish it will return to recovery menu, just choose "reboot system now"
When your system back, please, have a try with Kodi again and let us know.
THANKS AGAIN
Originally posted by Inphic
Thanks!
Now type:
THANKS AGAIN
Originally posted by trebor View PostThanks for the Update....
Tried with the APP for OTA all that did was drop me to recovery and could not do much from there.
Option 2 worked, downloaded burning tool from here http://chinagadgetsreviews.com/downl...-v2-0-4-3.html
Followed Instructions (pity cant see the reset button luckily I drilled it earlier) about 5 minutes to install new firmware.
It will sit at a loading screen while new firmware sets it self up on on the i5, takes awhile so don't Paninc.
Get greeted with new system to reset up, all apps wiped best to start fresh no junk in the trunk.
Remote works through complete process.
Version Now show KOT49H.20151113test-keys
I enlarged it as I prefer to use a tooth pick, a paper clip would fit, the idea sticking bits of metal in bothers me
CheersLast edited by INPHIC - Jim; 31 December 2015, 02:21.
Originally posted by trebor View PostI had some problem day one, only way was uboot button to connect
New XBMC In from Vidon much better,
I note Vidon is a paid service will there be some deal for Inphic users.
Also a Spanish update for Yomvi ? don't use, guess it may come in handy
Looking good
Cheers
We found vidon working a little better on SPOT i7, sometimes while playing dolby-hd it looks like vidon response is better when we choose AUDIOTRACK on "passthrough output device" at kodi configuration.
Hello peeps,
I received my i5 a few months ago, just really started playing with it. I have a Rikomagic box and stick, I bought this for the kids to use in their playroom, price and ethernet connection meant it was worth the small outlay, and I'm really impressed so far. i have a couple of questions and a few remarks.
I used the update apk, (I was going to flash with the tool, but my ROM download was corrupted and the MEGA file was removed) and as far as i can see my system is up to date. Great that it's rooted, I thought I'd be spending hours trawling the web to find a rooting process.
I had to install Rotation Locker app (on XDA and Play Store) as some apps (RAM manager, one Space Invader game etc.) were giving a small portrait screen image on TV. Anyone else had this problem? It's now locked into Landscape mode.
Live Wallpapers don't appear to work, are they supported? If you click on the Live wallpaper, it just says "App not installed" in the pop up.
Also noticed it's also going into "sleep mode?" , powers off, but the blue LED is still on. A post above mentions Screensaver mode, can someone tell me where that is? Never heard of it, and went through the settings menu again, maybe I missed it somewhere.
Where is it best to follow development? On this forum, is there also a thread on XDA?
Any info gratefully received, nice to see a manufacturer posting in community site's like this one, show's a good customer mentality.
Merci!
Can you tell me your build version? You can find this in Settings > Other
Originally posted by skivit View PostI had to install Rotation Locker app (on XDA and Play Store) as some apps (RAM manager, one Space Invader game etc.) were giving a small portrait screen image on TV. Anyone else had this problem? It's now locked into Landscape mode.
Originally posted by skivit View PostWhere is it best to follow development? On this forum, is there also a thread on XDA?
Merci!
There are currently 2003 users online. 0 members and 2003 guests.
