Inphic SPOT i5 S805 media Player
    How is everyone doing!
    Some betatester out there can give feedback of any antutu score up to date?
      Originally posted by INPHIC - Jim View Post
      If you can be able to open up the Spot i5 case, we can send you a new white case with the new controller. Could you please send your address detail information to this email?
      [email protected]
      Hi Jim!
      thanks, I've sent my emails few hours ago.
      Can you tell me, what did you do to improve stability in your Android build? I'm trying OpenELEC on the i5, and besides the lockups, it seems to be compatible with the MXQ build.
      Thanks in advance,
      peaquino
        Originally posted by peaquino View Post
        Hi Jim!
        Thanks in advance,
        peaquino
        Hi Peaquino,
        Your parcel has been sent.
        Sales will contact you to send you the tracking number.
          I received my i5 yesterday and it is different than the one in this thread.
          It has two regular size USB ports, no SD card slot and an "AV jack.
          Is this a new version or an old version?
          It also came with a Chinese interface :-(
          Does anyone know how I can choose the English language?
          Dave
            So after some digging it looks like they actually sent me the Inphic P8,
            The specs seem to be
            allwinner h3
            mali 450
            512M ROM
            8GIG EMMC
            From what I can tell this isn't available in the North America market so I am wondering if there is anything I can do.
            It is also running YUNOS at the moment. :-(
            Ó¢·Æ¿ËºÐ×ÓP8£¬ÊÇ×îз¢²¼µÄ4ºË¸ßÇåÍøÂç»ú¶¥ºÐ£¬ÍâÐÎÀàËÆÐ¡ÂøÍ·£¬¾«Çɿɰ®£¬±»ÓþΪ¸ßÇåµçÊÓ»ú¶¥ºÐÖÐ×îÆ¯ÁÁ£¬ÐÔ¼Û±È×î¸ßµÄ»ú¶¥ºÐ¡£
              [ATTACH=CONFIG]n559830[/ATTACH]
              Dave
              Hi, where did you buy this?
              That is a model for chinese market only.
                Yes, I have been talking to them and have found that out. They are not sure the I5 will work in Canada but I think it will right?
                  Inphic, can you tell me if the i5 will work in Canada please?
                  thanks
                    Hi, the SPOT i5 from this topic will work in Canada. But that P8... it is H3 with YunOS. Has the seller told you something?
                      Thank you
                      The seller says they can't get the spot i5 anymore so we are trying to find another S805 box to take it's place.
                      That makes me sad though because the i5 looks really good and the i7 looks even better.
                        I got the P8 from Dinodirect. It looks like they are trying to make it right now.
                        It looks like the Fick P8 might be similiar, does anyone have any firmware and/or instructions on how to get english on it or upgrade it?
                        inphic / British Fick p8 big bread quad-core network set-top box HD player Internet TV Box
                          Good afternoon, I have a problem. My i5 constantly freezes, put on a patch for the firmware recommendations 20151218, like more or less the same but immediately hangs when trying to play games. Updated system at the December (28 December 2015), it became more freezes, and the patch does not helps. Even now hangs in the normal use. What is the problem ? a feeling that the problem is in hardware, or just in a bad optimization?
                            Hi lev_mexico, Download the new firmware from here:- http://www.inphic.com/downloads/firm...-spot-i5-image
                            This should fix your freezing problems.
                            Cheers
                            Kevin
                              I don't know if is working on ota.
                              If you can use USB Burn Tool from here :-http://www.inphic.com/downloads/download/18-burning-tool
                              If you have not used it before I will find tutorial for you.
                              Cheers
                              Kevin
