Inphic SPOT i5 S805 media Player
Originally posted by trebor View PostChange log at all ?
Downloaded...
Installed....
Loading.....
All in and loaded......
set up WIFI ok
Google account ok
updating a lot of apps i don't use, uninstall soon.
So far so good
Cheers
Here comes some changelog-like info
This firmware version is is rooted, there's a patch/fix for crackle and yomvi, and vidon comes within the presintalled application pack.
That's all ... Actually it just a handy upgrade for those new to Spot it that need to catch up.
Originally posted by INPHIC - Jim View Post
Wow, you are insanely fast...
Cheers
Originally posted by kevin1341 View PostI have Ethernet work. Had to go in to settings and turn it on for some reason.
Vidon crashed for me.
Still having freeze ups by just move through the icons on the screen and have to reboot.
I am starting to think that I have a hardware problem.
Cheers
Kevin
Do not be worried about your device. Our sales team will help with warranty if needed.
Thanks for your help
Originally posted by Inphic View Post
You should have something like this:
Tried to flash the new update, recievied an error put me into recovery, tried to flash from within recovery, same thing happened again. Phone not finding photo to upload, post it from laptop soon.
Booted back up, still in 20151218 firmware.
I'll keep trying....
*EDIT*- started afresh, flashed no problem, seems stable, I had a bit of a stutter on Netflix last night, on the last firmware, that's gone now.
Everything seems stable enough, will see how adjusting cpu and memory affects it, so far everything seems okay.Last edited by skivit; 30 December 2015, 17:31.
Hi, an aditional question. Can you tell me your MAC? You can find it on the label at the bottom of your box.
Originally posted by trebor View PostDid you tick Wipe Data when you did the update,
best to start fresh and clean.
Installed here no problem
Cheers
I remember tick on Wipe Data before selecting the file and applying update. I retried again just now and I can now get apps from PlayStore. Suprise
Thanks Trebor for the reminder.
There are currently 2004 users online. 2 members and 2002 guests.
