Also, how do you swap out of mouse mode once you are in it? Only way I have found is to turn off the unit.
Ok, let's go one by one.
We are building a process to support our users.
When you press that "mouse button" you can see its pointer there. When you press same button again the pointer will disappear, then, it is back to normal function. It can take some seconds (but you do not need to wait, the control will response again even before the pointer disappear).
Do you mean the control remote learning funcitonality? Could you please explain me more about it?
hey, no, i don't mean learning functionality. i mean the remote is very weak. i have to go very near (one meter) to the device for the remote to work. otherwise nothing happens or i have to try pressing a button multiple times to get lucky.
Also, is there an update that could be done to keep the box on for a longer period when idle. It frustrates me, that for whatever reason I am not using it, it shuts down, and then we have to go through that 2 minute or so boot up.
Lastly, can an update be pushed to make the remote work better. Yes, I can run an app on my android phone to control the box, but I shouldn't have to?
The only way I got the remote to work properly was to take the board out of the box. Did try it back in the box with the clear lens removed and remote pick up fitted close to the front as possible on worked well.
I have had heating problem also with board the box so I found a piece aluminum and super glued it the s805.
When it got too hot it would freeze and had to be rebooted.
All up for the price it's a good little box to have a play with.
[QUOTE=kevin1341;
Kevin[/QUOTE]
Whilst the box is in working mode, I think it is a pretty good little unit, but simple remote problems and dnla stuff should be a priority they must investigate and give their attentions to.
Will your site like this one, which appears to have a forum or community section, be available in English? http://www.inphic.cn/bbs/portal.php
Actually we have the forum installed, but run a forum is something that takes lots of time and difficult to get a good amount of users there in short time. Then, we are trying to work off-page first. But the idea is to run our forum later or sooner.
Lots of things to be organizated and FT is a very good place to start (and continue)
