HPH RK3288 Lollipop ROM v1.1 by mo123
    HPH RK3288 Lollipop ROM v1.2 by mo123
    V1.2
    Rockchip Kodi based on Jarvis 16.0 beta 2
    GUI Resolution change - Go to System- Settings- Video to change to 720p or 1080p GUI
    Low bitrate internet streams artefacts problem solved.
    4:3 Aspect ratio videos can now stretch fullscreen non-linear
    Black screen problem solved(at least on a 1080p display)
    Music Menu works now
    PVR Addons installable
    Some addons preinstalled(Youtube, Reddit, Tunein Radio etc.)
    New HEVC FFMPEG 2.8.2 Codec
    Pulsar and other torrent addons working in Kodi
    Android menus speed improvements
    Soundabout app - To change audio settings for USB Audio(eg. speakers or airmouse) & bluetooth devices
    4K Video Player app can play videos in a window.
    Small SPDIF changes(Don't know if it will make a difference?)
    People with Black screens(mostly 4K tv's) see if you can select 4K resolution in Kodi Settings.
    Try to change Kodi GUI to 720p and see if 4K video playback black screens go away.
    Download Link: Here
    V1.1
    Fix Audio passthrough noise
    Fix Dynamic Refresh rate issue with 4K and other refresh rate 50hz/60hz switching
    Optimize 23.976 fps video playback
    Improve buffering
    More stable & custom NTMC
    - Videos stop after playback
    - PVR Addons support
    Download Link: Here
    V1.0
    Rooted
    8GB Userdata
    1080p Youtube
    MXPlayer with DTS/AC3 Codec
    Custom NTMC Media Player
    - Auto refresh rate switching
    -Rockchip Codec
    - Passthrough Support
    Download Link: Here
    (Use 7z to extract ROM)
    Flash Tool & Drivers: Here
    For people with UGOOS UT3,UT3S devices please flash this afterwards also
    Download Here
    It should enable the fan and overclock your device.
    (Just click 'Run' from the first screen after connecting your device in flash mode with a paperclip)
    Instructions:
    Before Installation
    - Make sure USB Power saving mode is disabled for the USB Port you use to flash the device
    - Use a PC Back USB Port and not ones from the front or a laptop
    - Pause Antivirus software for 10 minutes to not interfere with the flashing or cause high disk usage.
    - Make sure device was connected to PC before in flash mode and drivers were installed
    To Install the drivers
    1. If flashing for the first time, you need to install the drivers with DriverInstall.exe
    2. If you recently upgraded your operating system to Windows 8.1 or higher, it's also a good idea to install the latest drivers.
    3. Let your PC recognize the device and automatically install the drivers
    - Connect device with OTG Port and cable to PC
    - Now connect the power adapter
    - Before plugging the power adapter into the device, hold a paperclip into the reset hole of the device, keep holding it while connecting the power
    You will hear a 'click sound' that Windows has now recognized the USB device.
    - It will ask to install the drivers or install it automatically.
    Flashing the ROM
    1. Select 'Upgrade Firmware' in AndroidTool v2.35(Second tab)
    2. Click on the 'Firmware' button to load the firmware(update.img that you extracted from the 7zip compressed file)
    3. Click 'EraseFlash' to wipe your device, wait for it to finish.
    4. Click 'Upgrade' to flash the new firmware.
    5. Wait about 2 minutes after flashing and before unplugging device for firmware to settle.
    6. Disconnect from PC and connect to TV.
    Enjoy
    HD Audio
    Kodi
    You need to turn off the following settings in Kodi
    (But they should be disabled by default)
    - Keep audio device alive -- Off
    - Play GUI sounds -- Never
    HDMI Bitstream
    Android
    - Choose HDMI Bitstream in Android Sound Settings
    SPDIF Passthrough
    Android
    - Choose SPDIF Passthrough in Android Sound Settings
    The ROM was made for HPH & UT3 devices that have 16 or 32GB storage.
    The ROM doesn't boot on 8GB devices
    HPH RK3288 Lollipop ROM v1.0 by mo123
    Rooted
    8GB Userdata
    1080p Youtube
    -Rockchip Codec
    Download Link: Here
    Download Here
    Instructions:
    Before Installation
    Flashing the ROM
    Enjoy
    I will release an updated ROM in a day or 2 that will fix the remaining video playback problems.
    Thank you very much mo123, this room is very fast!
        I will upload a new version of the ROM today.
        It will fix all the remaining video playback problems.
          good, thank u very much.
            cheers mo
              Open /system/preinstall_kodi/kodi-addons.zip with Es File Manager.
              Choose to extract zip to /sdCard/Android/data, overwrite files.
                hi mo,
                can you compile a rom for firefly with resources and kernel .img ?
                thanks https://drive.google.com/file/d/0B55...ew?usp=sharing
                  Originally posted by gaetanolip View Post
                  hi mo,
                  Is it from the 20150910 Firefly ROM or where do you get those files?
                  Have you tested the 20150910 Firefly Lollipop ROM?
                  Is 4K video playback working correctly or is it in slow motion, just want to confirm.
                  If it is, with this kernel/resource it will also be in slow motion, if yes in previous question.
                  I tried the stock Firefly ROM but could only get slow motion video playback, think it's something to do with drivers in the kernel not working correctly.
                    the files re from latest lollipop sdk (firefly) did not try yet..the i saw also http://bbs.t-firefly.com/forum.php?m...extra=page%3D1
                      Does it support hd audio passthrough?
                        Hi Mo,
                        can you confirm that LP doesn't support 3G Sticks like E1550 K3765????Huawei Sticks.Tried it,doesn't work for me on Ugoos LP Beta and yours too.So LP is not to use for me,for the Rest nice Rom,but after Flashing and testing on my UT3 i had Sound Hicks and Stutters,flashed it with your Files for UT3 & UT3S.
                        Have a nice Day
                        gefattern
                          Yes, but need someone to test.
                            Hi Mo,
                            Have a nice Day
                            gefattern
                            You'll have to get the E1550 K3765 drivers that are compatible with Lollipop and then someone needs to build a kernel with the drivers included.
                              you got a final rom to come still mo ?
