HPH RK3288 Lollipop ROM v1.1 by mo123
    thanks mo123.....
    - audio settings are the first thing i do when i set up my box.
    - And those were the codecs i always use (and used for your v1.0) and they were loaded...., but unfortunately, no spdif passthrough....
    - Regarding the booting issue , they were also some dudes in that russian site (4pda) facing the same issue....
    blessing bro..
      It doesn't boot for me either although i erased the flash , i even did a lower format but still cant boot.
        ROM only works on 16GB or 32GB devices not 8GB ones.
        Have you tried flashing the v1.1 ROM after flashing the v1.0 one?
        The new ROM uses newer code so maybe there are components in HTC devices that aren't compatible with it.
        I'll try using older code or packaging the ROM differently and see what happens.
        Does flashing finish correctly and you leave the device plugged into the PC for around 5 minutes before disconnecting it?
          Hi
          Flashed rom on firefly. Hooked via hdmi to my TV.
          Audio randomly works (played with settings, hdmi ports, atm audio works. Let's see..)
          USB ports are ko, only usb otg is ok.
          Microsd reader is ok.
          Main problem : internal microphone is ko. Tried to use a bluetooth headset, it is connected but does not work. Any help?
          Inviato dal mio ASUS_Z00A utilizzando Tapatalk
            by the way mo123... would it be possible to have the .apk file of your kodi version? (i think it's called htmc...)
            thanks in advance bro...
              Originally posted by gaetanolip View Post
              Hi
              Firefly uses completely different audio hardware, so that why it doesn't work.
              I'll make a kernel for Firefly if I can get it to work.
                mo123.... were you able to fix the booting issue on v1.1 ? i tried to flash again my 16Gb beelink R89 but to no avail... thanks
                  Try flashing this kernel here after flashing the v1.1 ROM.
                  Leave device plugged into the PC 5 minutes before unplugging.
                  Then flash the new kernel after disconnecting and reconnecting the box.
                  It should show the bootlogo for about 5 minutes or less on a faster device.
                  Can also try this kernel/resource.img here.
                    thanks mo123 for being always there for us..... one last thing bro ; are there any rom modifications (as compared to v1.0) when it comes to mxplayer dts and dolby passthrough...?.
                    i've been always using your kk roms because of the great video play quality , i mean i can really feel the difference in picture quality as compared to other kk-based roms..... well , of course wasser's LP rom is the greatest when it comes to video playback so i strongly believe that your LP rom is also as good.........
                    blessings bro
                      blessings bro
                      I used the 1.7.32r1 DTS codec but hear people say the 1.7.32 one is better, so will use that one instead.
                      There is also a v1.8 MXPlayer out but I hear there is no custom dts codec for it yet.
                      Did any of the 2 files work for you or still have to test?
                      If the second file worked, did you try and see if 4K videos played correctly or were they in slow motion?
                        hey mo... was using last night and the only prob is that i get a black screen flick every 10 seconds or so..... its the kodi as i tried vid with other player and worked fine.
                          Try unzipping this file here to /sdCard/Android/data/org.xbmc.kodi/files/.kodi/userdata/addons with ES File Manager.
                          Then it should work.
                          What are the best PVR addons to use, then I'll only include those in the next firmware.
                          Test if latest Kodi has double stretch fixed on 720 feeds here
                          the 16 jarvis seems to have fixed all the probs ?.... 4.3 signal in 16.9 no probs.... and pvr working well with live tv.
                            You can try disabling RockchipCodec and only enable Mediacodec in Settings-Acceleration(Enable Expert Settings at the bottom) and see if it also plays 16:9 correct in the ROM Kodi, then Kodi Jarvis might not be necessary.
                              Have you enabled auto refresh rate in Android Display settings and auto refresh rate switching on /start/stop in Video Settings in Kodi?
                              Also try with it disabled and resolution set to 1080p 60hz and not auto.
                                Thanks mo
                                But why does my bluetooth headset (microphone) connect but not work (no microphone audio is recognized by the box).
                                The same headset works well with all my phones..
