HPH RK3288 Lollipop ROM v1.1 by mo123
wow Candy sent item with dhl even though i choose ems shipping i guess im paying even more money for this device when it arrives! not very impressed with this company's attention to details!Minix neo x7 custom quickshot V3.1 kitkat with cpu1700 video stock and oc ram 720 kernal
HTC Amaze 4g unofficial cyanogen mod 11 KitKat 4.4.4
ASUS Nexus 7 (original 2012 tegra 3) Cyanogen mod 12 Lollipop 5.0.2
For a permanent solution you can add
qemu.hw.mainkeys=1
somewhere in the /system/build.prop file and then save it.
Use ES File Manager, enable rw for / and /system folder in the bottom settings of ES File Manager.
It will ask for root permission, say yes
I will try to look for an app that does it, it seems the IR remote can't do it on this Lollipop.
Originally posted by marcelomelo View PostIn 1.2 version, after reboot screen when firmware update is finished, my tv screen gone blank.I have 4k tv.
Can you tell what model TV you have?
I can try to report it and see if updated HDMI drivers for the kernel can be made.
Can you try plugging the HDMI cable in/out from the tv while the box is on?
Also try plugging into a non HDMI 2.0 port on your tv if not all ports are HDMI 2.0, eg. a HDMI 1.4 port if available.
On most 4k tv's not all the HDMI ports can do 4K and spme are HDMI 1.4.
Also try plugging the box into a 1080p tv if possible and reconnect to the 4k tv later.
Hi
Same for me on my 4k TV : no go when setting auto resolution in Android: blank screen.To sort this out I had to connect my box on a 1080 TV and force resolution to 1080/60 then it would display fine on the 4k one.
I didn't test a 4k video though so I don't know if kodi can switch to the 4k res.
Also still the same problem with rk acceleration on : on some movies at the same timestamp the TV screen goes blank and try to detect the video resolution while sound is still playing
Nice to see you're working hard on this firmware
Same to me. It fixes when I plug on a 1080 TV.
I have another question: i have a beelink r89 and is it possible shutdown device instead reboot?
Well I've finally tested a 4k demo file and since the android settings are set to 1080p the file won't play at all with kodi (screen going blank trying to change resoluyion several time in a bootlop)
When trying to play with built-in player the file will play but only at 1080p
I can't set the screen resolution to auto in android settings since the TV goes blank.
Note : kodi interface is also set to 1080
Originally posted by thdj View PostWell I've finally tested a 4k demo file and since the android settings are set to 1080p the file won't play at all with kodi (screen going blank trying to change resoluyion several time in a bootlop)
It must be a problem with Rockchip Kodi or Rockchip Lollipop firmware giving a problem.
See if Kodi 15.2 or Kodi 16.0 beta 2 from Kodi website plays the video correctly.
Originally posted by heiko123 View PostHello Mo,
can you say why netflix dont play, yet?
Since Rockchip released Lollipop firmware lots of things that was fixed in KitKat firmware is now broken again in Lollipop.
I will try to fix it but not sure what is causing the problem. I also get just loading on a video, but not sure if it's a Netflix or VPN issue, since Netflix is not available in my country and sometimes VPN services cause it to hang so it makes it more difficult to troubleshoot.
If I don't get it working I'll just upgrade my v1.1 ROM with the new Kodi and test Netflix on it also.
There are currently 3513 users online. 0 members and 3513 guests.
