INPHIC SPOT i7 (S905)
    Interesting, thanks for the link. You may get your wish.
      Their boxes are great boxes and run a great auto updating service.. but not interested in all that tbh.. just a few of us have a spot i7 so would love a straight box Openelec instal..
        As I know, Maiz box is running openELEC over SPOT i5 (S805), it is not the SPOT i7 (S905)
          Aaaa so it's the i5 version not the i7. Sorry for the mistake.. Ooooo well.. looks like it's the long version to get Openelec on the i7. Thanks for the info :-)
            Originally posted by RISCy Dude View Post
            It installs with USB Burning Tool, but if I remember correctly, sometimes a manual install will overcome connection issues. I have done it myself. Right-click the exe and run as administrator.
            ok
            i'll try tonight
            thanks
              Hi Inphic, Could you please post the change log for the new firmware.
              Cheers
              Kevin
                Im having issues with device running very hot and system hangs. Running Kodi 16.1 mkv movie @720 that is actually paused and left for an hour. After that i cant do anything just pull the plug from the device and wait for it to cool down.
                The other probles is remote. It doesnt work every press (I have to press sometimes 2-3 times a button for it to work - no problems when using programed buttons on the tv).
                  Originally posted by luffy View Post
                  ok
                  i'll try tonight
                  thanks
                  no change
                  i'll try with another cable...
                    Hi all, Here is my finished Spot i7 project.
                    Click image for larger version  Name:	IMG_0002.JPG Views:	1 Size:	5.1 KB ID:	574780
                    Click image for larger version  Name:	IMG_0007.JPG Views:	1 Size:	5.8 KB ID:	574781
                    Click image for larger version  Name:	IMG_0012.JPG Views:	1 Size:	3.9 KB ID:	574782
                    Click image for larger version  Name:	IMG_0015.JPG Views:	1 Size:	4.6 KB ID:	574783
                    Click image for larger version  Name:	IMG_0017.JPG Views:	1 Size:	4.1 KB ID:	574784
                    The yellow block near the fan is a smart speed controller :- http://www.****.com.au/itm/Smart-Spe...IAAOSw-0xYeJl4
                    The fan is one of these :- http://www.****.com/itm/1pc-ADDA-Dua...-/170739153418.
                    The wi fi antenna and socket was from a cheap dongle I had.
                    Temperature sits at 49c idle and about 54c at stress test.
                    Very happy with the unit.
                    Cheers
                    Kevin
                    Last edited by kevin1341; 15 January 2017, 12:43. Reason: Tried to change link to new ones
                      Hello Kevin, Nice symmetry on the holes. For temp comparison, it is always good to list the ambient(room) temperature at the time of testing. The i7 is a fun one to mod.
                      Good job.
                        Hi RISCy Dude, ambient temperature was about 23c at time of test.
                        Cheers
                        Kevin
                          Hmm
                          Maybe wrong but I do see a slight resemblance Click image for larger version
                          But then someone also suggested
                          Looks good
                          Cheers
                            Good decision.
                            The lower metal plate deleted ?
                              Hi bales150,Yes got rid of metal plate to help air movement.
                              Cheers
                              Kevin
                                IMHO
                                It would be useful to add holes around the circumference at the bottom of the top cover. Feet very low and the access of air through the holes in the bottom cover is weak.
