INPHIC SPOT i7 (S905)
    kukulaj thank you for posting the link.
    I will give it a go.
    Cheers
    Kevin
      Thank you .
      Root works great.
      I will be able to install Titanium Backup Pro on again.
      Cheers
      Kevin
        Originally posted by Viri View Post
        My spot i7 doesn't see an OTA update or it updated so fasts i didn't notice. How to check current version (system info ?)?
        Where is the list of update changes ?
        Hi
        Same Thing
        No OTA update
        Impossible to use usb tools
        spot i7 never detected
        and the mac adress of my spot i7 change every time i restart the box !
          Originally posted by luffy View Post
          Hi
          Same Thing
          No OTA update
          Hello luffy,
          What usb tools are you using?
          What MAC address does change? Ethernet or WLAN address?
          If you need to flash you device with the burning tool, you should use the USB port is on the top.
          If you happen to see a red number below either KEY or AVAILABLE column while failing to burn, you can use this simple quick-fix patch to fix it http://inphic.com/downloads/tools-dr...ing-tool-patch
            Hi Jim
            i've downloaded it on your web site
            I use the usb top port
            the i7 was never detected
            so i can't try to flash anyway
            should i use a "special" usb cable perharps ?
            the ethernet Mac address change every time i restart
            so i can't configure my router
            thanks for your answer
              luffy what cable are you using. Look at some of my posts and trebors and they might help you.
              Do you have a cable like this:- http://www.****.com.au/itm/2M-Type-A...-/200642038176.
              Cheers
              Kevin
                luffy with your ip address changing on boot up I think that is normal.
                You have to set up a static ip address in your modem/router or on the spot i7.
                I will have a look in my i7 for you.
                Your mac address should not change but your ip address will.
                Cheers
                Kevin
                  Cheers
                  Kevin
                  Unfortunately, a lot of these boxes have the issue of the MAC changing every reboot. I have had several of these boxes that had that problem, the latest box was my Tronsmart R68. I had to use a patch to keep it from changing the Ethernet MAC address each boot.
                    clarkss12 Thank you for that information.
                    I have just boot my box up after unplugging the power pack 4 times and my box is not changing mac address.
                    I wonder if it a problem with the old firmware.
                    It might be OK when luffy gets the new firmware flashed on his box.
                    Cheers
                    Kevin
                      Kevin1341
                      i use a same cable
                      and that's the issue describe by clarkss12
                      ethernet mac adress change every time, impossible to assign a static ip by router
                      so i assign static ip on android's spot i7
                      thanks
                        Hi luffy Did you look at my posts on flashing the i7
                          Hi Jim
                          Hi luffy,
                          Could you tell me what's the MAC address you have right now on your Spot i7 and what's the firmware version?
                          And the MAC address printed on the label is on the reverse of your device?
                            Hi. Can't flash the box using .img. In "USB_Burning_Tool" crash bug "get key failed". Sorry for google translator .
                              Download and try, this should fix problem
                                kevin
                                yes
                                i'll try with another cable
                                @jim
                                build : spot_i7-20151230309
                                ethernet MAC 3e:fb:7d:e5:df:7b
