INPHIC SPOT i7 (S905)
Originally posted by Inphic View Post
So, good news, some ones are going to try soon
For all of you that use the Mobdro app here is the new one:- https://updates.mobdro.com/downloads/mobdro.apk
The old one would stop working on my Spot i7 but the new one is working great.
Cheers
Kevin
Originally posted by trebor View PostIt sits in the 70's that's ok, best temp was 114c before the mod, idle now 40~50 so it has to help.
A nice tight sandwich when you put the lid on and you hear nothing...Shhhh and the plate out of the base also.
Cheers
Originally posted by trebor View PostOut of the box and running, I was shocked also...
My mod kept has kept it cool it was a software monitor so +/- 10 or so.
Cheers
while :; do sleep 1; echo -n "TEMP: ";cat /sys/devices/virtual/thermal/thermal_zone0/temp;echo -n "FREQ: "; cat /sys/devices/system/cpu/cpu0/cpufreq/scaling_cur_freq; done
You also can use your phone and terminal, it will look like a cool monitor :-D
You can connect by adb and type:
Temperature and CPU frequency updated every secondAndroid TV Box direct from China. English & EspaƱol
There are currently 3302 users online. 0 members and 3302 guests.
