INPHIC SPOT i7 (S905)
You will need to open a "SPOT i7 Modding" topicAndroid TV Box direct from China. English & Español
Oh yer it was hot as....using the Ice storm extreme 3dmark tests
The Scores for what they are worth much the same as the Tronsmart S905
The only 1/8 GB does struggle when pushed like most 1/8 units.
Does as expected for what the Inphic i7 is, a couple of minor bugs in there rom ! in the WIFI
All in all not too bad at all, Wi-FI and ethernet speeds ok
As mentioned Plex and Netflix very watchable
Looks kinda groovy only disappointed, I now have two white remotes so confusion has struck again
Cheers
Originally posted by kevin1341 View PostHi Inphic, Could you please post the u-boot.bin file for the i7.
My i7 stopped working over night and all I get is the red light.
It had switched its self off sometimes but had started after using the remote.
Tried to get pc to recognize it but it would not.
Opened up unit and found that it has no reset button on the board.
Will try to fix it when I have the u-boot.bin file with sd card.
The unit has been working great with all the apps that I listed in my first post.
I did have it changing volume by its self sometimes in different apps.
Cheers
Kevin
Originally posted by Viri View PostMy spot i7 doesn't see an OTA update or it updated so fasts i didn't notice. How to check current version (system info ?)?
Where is the list of update changes ?
If unsure you can do a manual update from files below also listed is the changelog
Cheers
Updates
Changelog
Current version
There are currently 2439 users online. 0 members and 2439 guests.
