Modded ROM's for Tronsmart R68 "Tronsplant your ROM"
Sd card doesnt work and no blue power light...and no bluetooth unless i flash the wifi bluetooth fix thus then kills wifi and only blue tooth works..
Is there any fix for this i can not flash and thing from my stock rom because the seller on amazon wont share it on another site othet than baidu...box Rupa i68s, it is same as the beelink i68...same hard ware same all i guess i await a fix? That be most cool
Originally posted by Stzo View Post
Do you know how to disable update?
Originally posted by robot20 View PostThis is what worked for me on windows 10 using 1.39
Uninstall drivers,
Install drivers
Pick the image to flash 9.5
Attach power plug and OTG cable.
Press start
Press rest button on bottom of box with pin.
Flash should start.
Hit stop when completed.
Originally posted by robot20 View PostThe activation fix should be included in ROM. I never had an activation error. My wifi worked fine. I never checked the blue tooth (not needed in my case).
There are currently 1705 users online. 0 members and 1705 guests.
