Modded ROM's for Tronsmart R68 "Tronsplant your ROM"
    lonix
    v9-5 version works really well on my device even works perfect the spdif passthrough PCM and DTS for optical.
    The only problem is the Ac3 passthrough (Dolby digital) does not work on any player, my physical receiver puts Dolby digital but does not detect channels (I can see this on your screen) or audio, however with DTS works perfectly (I have tried several files Videos and various players)
    (Android is set to SPDIF passthrough)
    Any patch or change I can make?
    Thank you very much
      Which version of Xposed Framework works with this ROM? I flashed xposed-v86-sdk22-arm and it seemed to go fine but then I just get black screen and it's not booting to the main screen. Now I need to load the ROM again but I want to make sure I try the correct version of the Xposed Framework after.
        Love this rom any chance of a update to the latest base?
          I'm sure that other people have already seen this, but if lonix ever decides to update his already almost perfect work, then octacore hack might be a good supplement:
          More info here: http://freaktab.com/forum/tv-player-...f-2#post611264
            ... there's currently one outstanding bug in my code; power functions don't work properly after altering the power domains. The bug affects any firmware with the modified code. I've stopped development going forward until I solve this bug. I fixed a power domain issue a few months ago but this time it's crept back. I know the cause, the issue is solving it without breaking the hack.
            It makes rebooting and sleep not work properly.
            ...I test on a Z4 and it's about a 13,000 point difference system-wide, from stock. Biggest gains are of course in processing.
              Does this rom work thr first batch of tronsmart R68 100Mb Version ?
              Thanks in advance for your help
                Wifi won't work.
                  Wifi won't work.
                  Again Thanks a lot for your quick help.
                  If you have time, can you please give your advice about following steps to make ap6330 wifi work:
                  1) Extract Kernel and resource images from Tronsmart Rom
                  2) Flash this Modded Rom
                  3) Flash (Overwrite) the extracted Kernel and resource.
                  Does this fix the wifi problem for ap3360 ?
                    Will this help? I have the original R68 non gigabit also, and this is how I use different Roms, with original remote and WiFi working.
                    Auf YouTube findest du die angesagtesten Videos und Tracks. Außerdem kannst du eigene Inhalte hochladen und mit Freunden oder gleich der ganzen Welt teilen.
                      https://www.youtube.com/watch?v=7UGmgh4gjBw&t=242s
                      Hi clarkss12,
                      Of course, the video is very useful. I will try your way.
                      I would like to have DTS/5.1 via spdif on my R68.
                      Do you have a Rom that spdif is wroking with Kodi ?
                      Again thanks for your help.
                      Edit: It's working. I can flash the modded rom .
                        hi I am looking at upgrading my rom from v-9 full rom to v9.5 that has the latest kodi 16.1.1 does this delete everything I have on my android eg other apps will I have to set up the wifi and bt again or will this stay the same??
                          Yeah, it does. I just applied it. I use ES Explorer to backup my apps to USB stick and I do a Kodi Backup to the same USB stick. Makes recovery of your apps and Kodi settings a little easier. No silver bullet, pitboss1972. ZDMC is indeed 16.1 and the ROM seems to be pretty solid with the little testing I have done.
                          Nvidia Shield (2017 & 2019), A95x Max, WD EX2 NAS
                            On my beelink i68G, I can't seem to get ac3 passthrough via spdif working either. It doesn't pick up that there is an audio stream at all if I have it set to 2.0 with passthrough enabled in zdmc. If I set it for 5.1 output with ac3 encoding enabled, I get decode error messages on my receiver with no audio. When trying SPMC, the same issue is present, but the 5.1 setting output sends out static. Hopefully there's a solution?
                              So are you saying leave it a lone to rom I have v9 or update to 9.5, also can I put any build over top of this through ares wizard??
                                The process refreshes all partitions (except recovery) on the box. You lose your stuff. This is why I backup apps & Kodi. A little time consuming to recover, but worth the effort. 9.5 is not giving me any real issues.
