Modded ROM's for Tronsmart R68 "Tronsplant your ROM"
Who needs a tv android box to run as is?
1.Full screen on all applications
2.DRM L1 level, to see Netflix ultra HD
3.That is consistent with the launcher Android TV
4.There is no stuttering, the image is not frozen
5.Support for multiple APK, Android TV
6.SPEED AND AGILITY IN PROCESSING
ionix, excellent work. Maybe need more, work, but for me is the better work. Totally funcionability.
Hi All,
First of all thanks very much for all your hard work - this is great! Can anybody point out how I can install the flashable zip V7? I've installed the modded Ugoos UT4 rom via the flash tool ok but how do I flash the V7 zip?
My box is a Beelink i68 1000Mbit ethernet.
Sorry if I missed the instructions somewhere or if I'm missing the obvious :-)
Many thanks,
herges
I wanted to mention several positive points that have this firmware, much higher than the original and has several on the market.
1. I must stress that no freeze
2. Applications as YouTube, Vevo, flowing much better
3. Wireless is excellent
4. I have some movies on the site Vudu (Walmart), could not see any movie. This update lets me watch movies in HDX, I do not think there is a TV box that has reached this update. Obviously certification TVBox with google could run this application.
5. Stuttering is non-existent, has been met with a slight pause, does not cause frustration.
6. I'm not subscribed to Netflix, Hulu but the application without problems, CW, no problem, Only bad aplication for me is VEvoTV (extracted from fire tv box) not working.
Before working smoothly, an application of fire tv works is that if vimeo, totally surprised.
An application can enlarge the screen,
Hide System Bar (Full Screen)
Many thanks,
herges
Better to flash the full Rom, using batch tool or factory tool
Originally posted by lonix View Post
There is no way to go from the Ugoos rom to the Zidoo rom with TWRP because the parameter file needs to change, the parameter file defines the partitions.
DOH! - the Full ROM link does not show underlined so I did not realise this was actually available for download. Installed it now and looking good so far.
Many thanks
herges
Hi lonix,
i install Ugoos ROM on my Tronsmart R68 using Factory Tool 1.39 and after the first boot the logo is stuck or black screen, i did it twice.
i tried to install the Zidoo v5 the same way and i get black screen, i did clear cache on both using recovery and i didn't help.
could u post a guide how to flash Ugoos&Zidoo ROM on the Tronsmart R68.
i'm running now Wasser 3.1.3 on my R68
tnx
Hello Ionix. First of all, thanks for all the work that you are doing and of course all the people who are working on it. I don't have much knowledge how to update. I want to install v7 but don't know how. I installed first v5 with factory tool 1.39. How can i update to version 7? I rebooted into recovery mode (TWRP) and installed it from there. But when it finished and i rebooted nothing happened. I get a black screen. Did i something wrong? Or maybe there is a more simple way? Thanks a lot!
I saw that there was also a full rom version so i could install it in that way. Thanks again!Last edited by blackadder; 04 February 2016, 15:20.
Originally posted by blackadder View PostHello Ionix. First of all, thanks for all the work that you are doing and of course all the people who are working on it. I don't have much knowledge how to update. I want to install v7 but don't know how. I installed first v5 with factory tool 1.39. How can i update to version 7? I rebooted into recovery mode (TWRP) and installed it from there. But when it finished and i rebooted nothing happened. I get a black screen. Did i something wrong? Or maybe there is a more simple way? Thanks a lot!
tnx
Hey Guys,
Just a quick one, Zidoo have released their v1.0.32 rom, but i cant see anything compelling me to update.
here is the changelog.
Code:[COLOR=#141414][FONT=Georgia]ChangeLog:[/FONT][/COLOR] [COLOR=#141414][FONT=Georgia]1. Solved the issue that can't call up the virtual keyboard when connected such Bluetooth or airmouse devices(Must Restore factory settings).[/FONT][/COLOR] [COLOR=#141414][FONT=Georgia]2. Added support to multicast screen.[/FONT][/COLOR] [COLOR=#141414][FONT=Georgia]3. Removed the power key define on the settings(you can long press power key to define it)[/FONT][/COLOR] [COLOR=#141414][FONT=Georgia]4. Removed zidoorepo in the "Settings-->About"[/FONT][/COLOR] [COLOR=#141414][FONT=Georgia]5. Modify the poweroff UI, more easy to operate it,Can define the power key actions.[/FONT][/COLOR] [COLOR=#141414][FONT=Georgia]6. Improve the virtual mouse, fix the bug of repeat disappear and appear.[/FONT][/COLOR] [COLOR=#141414][FONT=Georgia]7. It can show the video information with pressing the 'O' on the remote control in the native player.[/FONT][/COLOR] [COLOR=#141414][FONT=Georgia]8. Optimized kodi, add auto-reflash framerate; pre-installed the related dependent library for the addon.[/FONT][/COLOR] [COLOR=#141414][FONT=Georgia]9. Solved the issue that only can identify two usb storage in one usb port.[/FONT][/COLOR] [COLOR=#141414][FONT=Georgia]10. Added support for RII i8 and RII i25 airmouse.[/FONT][/COLOR] [COLOR=#141414][FONT=Georgia]11. Solved it cannot save system volume in settings.[/FONT][/COLOR] [COLOR=#141414][FONT=Georgia]12. ZIDOO Media center[/FONT][/COLOR] [COLOR=#141414][FONT=Georgia]a. Optimized the reflash the UI when the storage plug out.[/FONT][/COLOR] [COLOR=#141414][FONT=Georgia]b. Optimized the loading issue with long time or failure, especially for adding device in the form of the host name on SAMBA.[/FONT][/COLOR] [COLOR=#141414][FONT=Georgia]c. Fix the error on the device listbar when plug out device quickly.[/FONT][/COLOR] [COLOR=#141414][FONT=Georgia]d. Optimized the support to save mounted device, to prevent users from wrong operation.[/FONT][/COLOR] [COLOR=#141414][FONT=Georgia]e. Solved reading the label name distortion on USB device.[/FONT][/COLOR] [COLOR=#141414][FONT=Georgia]f. Solved appear "unknown error" when open folder on the SAMBA device.[/FONT][/COLOR] [COLOR=#141414][FONT=Georgia]g. Fix the bug of the storage plug in dialog didn't disapper.[/FONT][/COLOR] [COLOR=#141414][FONT=Georgia]h. Solved no response and interface stucked when used Quick Search way to search frequently.[/FONT][/COLOR] [COLOR=#141414][FONT=Georgia]i. Optimized the acquisition mode for USB device volume label.[/FONT][/COLOR] [COLOR=#141414][FONT=Georgia]j. Solved device flashes back sometime when entering SMB with Address mode.[/FONT][/COLOR]
Yeah nothing crucial there worth of update. I am still on V6 and it works perfect. I saw that some people had problems with flashing V7, so I am still lazy to backup everything before flashing
Anyway, tried to install xposed on every possible way I found on the net, but no luckDid anyone successfully installed exposed on any RK3688 device?
Dear Ionix,
The auto refresh rate of the display in KODI (para 8) is a useful feature, if it works well. (I assume, 'reflash framerate' could be
mistyping only in the description.)
Is this feature implemented in KODI of v6 or v7 versions too? If not, it worth a try to move towards this ZIDOO 1.0.32 version.
Other small fixes seem stability enhancements, can live without them, but they make the system better, I think.
Thanks, STZORegards, STZO
Originally posted by DaPimp View PostYeah nothing crucial there worth of update. I am still on V6 and it works perfect. I saw that some people had problems with flashing V7, so I am still lazy to backup everything before flashing
Thanks, STZO
but ill look into it more.
Code:persist.sys.video.enable24p=0 #persist.sys.video.enableChangeResolution=1 #persist.sys.video.refreshRateFirst=1
There are currently 3188 users online. 3 members and 3185 guests.
