Modded ROM's for Tronsmart R68 "Tronsplant your ROM"
Originally posted by lonix View Post
Please try this version of kodi ( original zidoo)
To install, uninstall current kodi
Unzip to root of a USB stick
Install .apk using USB install app
Reboot to recovery using quickboot
Install librkffplayer using TWRP recovery
Click install change to usb storage and select file to flash
Thank You! it's work!!TRONSMART R68: Firmware "HPH NT-V8 ROM V1.2 (Dual-Boot) by mo123" (DTS-HDMA, Work)
ONKYO: TX-NR 809
Originally posted by DaPimp View PostDid anyone tried to flash it on Tronsmart device? And do we lose TWRP if we flash it?
I just flashed the firmware on the tronsmart r68 meta.
work great but,
the green/pink ( hdmi handsake ) is back
Lonix can you fix it?
the only rom the work good and dont have the "green/pink" problem is :
Originally posted by neonflx View PostI loaded zidoo v4 , immediately after i received my r68 today, the issue is that i keep getting this message about activation information, state: illegal authorized.
i then loaded v1 and afterwards v4 still having the same issue.
any suggestions?
Originally posted by myshedy View Posthi
there a fix for the green/pink problem in this version?
I requested the changes from Tronsmart on their forum, but they have not replied. Zidoo says its caused by hdcp handshake with older tv's,
for you i can make a stock tronsmart kernel version but it may have other issues.
im willing to try any rom you build. the ugoos with the stock kernel work allmost perfect!!!
I got a question :
if the rom got twrp recovery can you make a update zip for the kernel only? ( if the kernel is the key to the problem )
so I can use you main zidoo rom and then only update kernel...
give me 20Mins to make something and test it
I update me post ...
see if me idea maybe will help...
I got a question :
because I know there a lot more pepole in the tronsmart fourm that have this problem... and will love a solution.
thanks
again
you read my mind, here it is
https://mega.nz/#!aBoliLoD!9Mzvzzs_q...xuX3xb8E2WlF_Y
flash from recovery
EDIT: I will update the main post with this and instructions
There are currently 2051 users online. 1 members and 2050 guests.
