Modded ROM's for Tronsmart R68 "Tronsplant your ROM"
I flashed my Vic Tsing I68 (beelink I68 like) with zidoo v1, v2 and now v4. In all cases, the wifi/bt does'nt work. With Tronsmart 205L1 stock ROM all is OK. this box has a AP6330 wifi/bt module !
How i can do to have wifi/BT ? I saw dmesg from Tronsmart and zidoo, both uses AP6335 driver !
Originally posted by oldhouse View PostWill you release something for 100 MBit version?
https://mega.nz/#!jcJ0RQqL!h6eGC0xBB...ndeldRzJGQsbnM
Unzip to USB stick
Flash the v3 or v4 rom
then
reboot to TWRP then select install
Then select image(bottom right)
Then select boot.img and then select the boot partition
Then do the same for resource.img, to resource partition
Let me know how it goes.
Hi!
Have install test V4 FULL ROM, but with Bluray iSO in KODI 16 is very Bad!! :/
- Hold menu bluray no work
- DTSHDMA OK but Lip-sync problème
Kodi 15.2 is better.
Possible to add link APK or other for re-install Kodi 15.2
Great Job for V4! Thanks!
You have Paypal DONATION Link?TRONSMART R68: Firmware "HPH NT-V8 ROM V1.2 (Dual-Boot) by mo123" (DTS-HDMA, Work)
ONKYO: TX-NR 809
Ionix, here is news for you .... As you, I get very nervous about this crappy boxand as I had enough time today, I installed every possible rom released for rk3688.
Finally stumbled on this http://chinagadgetsreviews.com/downl...-tv-box-3.html
Installed it. It takes a lot time to boot, and after it boots it says something like: wait preparing box ..... I dismissed it with going straight to home screen.
As on all fw's tried first youtube and spotify, and got a lot of freezing/stuttering..... unusable.
After that and initial setup, gone to settings and seen new thing in settings: Sound device manager. Pic : http://i.imgur.com/uDyDDLn.png
In there, I changed option from default to spdif (same is and with HDMI). Pic: http://i.imgur.com/3hEBOtM.png
After changing it, all problems gone. 0 freezes/stutters in Youtube, even with overlay on video!!! Same with Spotify. Didn't setup Kodi yet, but I bet it will be ok too.
Ofcourse, I have red light on box, as I didnt flashed Tronsmart kernel, but beside that.... everything (finally) works perfect. I hope it will stay like that
Originally posted by reksio34 View PostHi Ionix,
I flashed with with kernel (16mo file) from stock ROM 205_L1. Same issue : no wifi/bt !
Another idea ?
Sorry at this point my work is only for educational purposes. I dont feel right about taking money from zidoo
Originally posted by DaPimp View PostIonix, here is news for you .... As you, I get very nervous about this crappy boxand as I had enough time today, I installed every possible rom released for rk3688.
Hey, I just checked, this feature is already in Zidoo rom, in Settings --> Sound & Notification ---> Audio Output.
Silly me, I had to decompile the .apk to find this.... derp
Originally posted by lonix View Post
Please use the link from post #45
Sorry at this point my work is only for educational purposes. I dont feel right about taking money from zidoolol
ONKYO: TX-NR 809
There are currently 1630 users online. 0 members and 1630 guests.
